Torque specs for zzp stage 4 clutch??
When tightening down the flywheel bolts use a star pattern and also torque down in stages. First torque to ~15ft/lbs and then go back around and torque to the full 39ft/lbs plus an additional 25 degrees. Thats if you are using the factory bolts.
imagepower
12
Oct 30, 2015 07:50 PM
