Transmission Torque specs
Old Aug 15, 2007 | 10:57 AM
Navyflyer11's Avatar
Does anyone know the troque sequence for the bolts on the bottom of the transmission pan. I also need the Troque specs if you have them.
I hit somthing and bent the front. I think its now leaking at the rear of the pan, so I want to re-troque the pan. I found the filler port on the top of the trans to add fluid.
Thanks,
Jeff
Old Aug 15, 2007 | 02:41 PM
GuitHHR's Avatar
Its 10 N.m or (89 inch lbs). They don't give an order for tightening the bolts.
Old Aug 16, 2007 | 08:00 AM
Thank you. That sounds a bit high for a bolt with a 7mm head that goes into an aluminum case?
Old Aug 16, 2007 | 08:37 AM
the_shmoo's Avatar
Just a heads up, that is 89 inch/pounds or 7 to 8 ft/pounds. Just being cautious.
Old Aug 16, 2007 | 09:11 AM
cc732's Avatar
If it still leaks after tightening @ 10Nm, you may want to change the pan and gasket. The gasket is a nylon compression type and may not re-seat exactly the same as before, and the pan could be slightly warped.
It's installed here in Windsor by a "multi" socketed machine.
Clare
Last edited by cc732; Aug 16, 2007 at 12:09 PM. Reason: wrote 7, should be 10 for "tap-tite"
Old Aug 16, 2007 | 11:59 AM
Black Rose's Avatar
I'm surprised it's that low. The plastic cap for the oil filter requires more torque than the transmission bolts.
Old Aug 16, 2007 | 12:15 PM
cc732's Avatar
The filler cap has a "pipe thread", and not often removed.
The case and channel plate are soft to accomodate our tooling and the use of "tap-tite" metric bolts.
Old Aug 16, 2007 | 01:50 PM
Thanks all,
The gasket is $50.00 and the pan is $89.00. I will try to torque it this weekend.
Old Aug 16, 2007 | 01:52 PM
Thanks,
Jeff
Could this have happened during your stunt driving?
Just glad your getting it fixed that is a sweet HHR!
Old Aug 16, 2007 | 02:56 PM
Not sure? started leaking about a week later though.
