Turbo
Is there a way without carrying the car to a dealer to see if the Turbo is performing efficiently?
Originally Posted by Resoplayer
(Post 710429)
thank you.....are there any rules of thumb/average on Boost pressure...
This past winter I had something strange happen....was shifting thru the gears, getting down on it a little and heard a loud noise from under the hood...like a muffler had come loose, occurred. I thought I had blown something and pulled off the road, cut the car off and back on and it was running fine?? Has not happened since and was not sure if this was from the Turbo or not..... |
Sounds lke one of the boost pipes popped off, seen it posted here a few times.
thanks, I'll check it.........
If the boost pipe popped off, you would definitley notice it. The car wouldn't be running right.
You stated that it was running fine now and you haven't had any more issues so it won't be a boost pipe. How much boost are you getting now? If a pipe was off, you wouldn't get any. |
(Post 710444)
I'm right in that range....watched it last night and in first and second 10 to 12 and in third it's around 16.
