Turbo
Old Jun 27, 2013 | 10:01 AM
Resoplayer's Avatar
Turbo
Is there a way without carrying the car to a dealer to see if the Turbo is performing efficiently?
Old Jun 27, 2013 | 11:12 AM
badassbowtie's Avatar
I would say by sound and boost pressure....measuring air volume? I am not sure if a dealer would/could even do that
Old Jun 27, 2013 | 11:49 AM
Resoplayer's Avatar
thank you.....are there any rules of thumb/average on Boost pressure...
This past winter I had something strange happen....was shifting thru the gears, getting down on it a little and heard a loud noise from under the hood...like a muffler had come loose, occurred. I thought I had blown something and pulled off the road, cut the car off and back on and it was running fine?? Has not happened since and was not sure if this was from the Turbo or not.....
Old Jun 27, 2013 | 12:07 PM
prod's Avatar
Sounds lke one of the boost pipes popped off, seen it posted here a few times.
Old Jun 27, 2013 | 12:09 PM
Resoplayer's Avatar
thanks, I'll check it.........
Old Jun 27, 2013 | 04:48 PM
If the boost pipe popped off, you would definitley notice it. The car wouldn't be running right.
You stated that it was running fine now and you haven't had any more issues so it won't be a boost pipe.
How much boost are you getting now? If a pipe was off, you wouldn't get any.
Old Jun 27, 2013 | 05:03 PM
Unturned you should hit 12-17 psi depending on elevation and weather conditions.
Old Jun 28, 2013 | 08:04 AM
Resoplayer's Avatar
I'm right in that range....watched it last night and in first and second 10 to 12 and in third it's around 16.
87silver
Racing Discussion
0
Nov 29, 2010 08:01 PM
TurboTechRacing
2.0L Performance Tech
0
Oct 28, 2009 09:03 PM
Hotrodbob
May 8, 2008 01:06 AM
Lone Ranger
Feb 9, 2008 06:04 PM
