Wideband options
Old Aug 24, 2011 | 06:42 PM
EcotecRacer's Avatar
Wideband options
What is everyone using for wideband?
was looking at the Interceptors but they require additional adapters
do any of the widebands out there use our factory 02 sensor/bung?
Old Aug 24, 2011 | 07:04 PM
asanti's Avatar
Our factory O2 IS a wideband right from the factory so the Interceptors will work fine. The extra adapters are for those times you want an external wideband O2.
Later
Allex
Old Aug 24, 2011 | 08:25 PM
so when i install the aeroforce gauges it will read true wideband correct?
Old Aug 25, 2011 | 05:46 AM
foolmoon_design's Avatar
Yes, if tapped properly.
Old Aug 25, 2011 | 06:39 AM
RobSSTurbo's Avatar
Yup,You got to setup to read A/F and then your in business.
Old Aug 25, 2011 | 07:25 AM
bartSS's Avatar
Nothing to tap just plug it in to your OBD2 and youre good to go
Old Aug 25, 2011 | 01:05 PM
asanti's Avatar
^^ THIS. Super easy.
Old Aug 25, 2011 | 06:25 PM
I only ask this cause Aeroforce has argued with me for over a week saying it will NOT read wideband and i must by their adapter kit to read wideband
Old Aug 25, 2011 | 07:22 PM
Tominator's Avatar
Many of the wideband gauges were developed under a previous standard. Many aftermarket wide band O2 gauges are stand alone. Not OBD2 compliant.
On our HHR SS the gauges must be wired directly to the gauge, not through the OBD2 port or as in the above case, the adapter is required.
Old Aug 25, 2011 | 07:52 PM
ATLsilverSS's Avatar
dude.....i can read wideband off my elm bluetooth and torque app for android
