ZZP exhaust
Nope, the tube that extends outward for the O2 is designed so it does not. It is an option while buying it.
Sounds amazing coupled with stock exhaust, and the downpipe is where you'll find the main restriction, our factory exhaust's flow rather well for the stock K04.
When choosing your options did you add for a standard 02 bung?
For the bung to extend outward and avoid codes you want the angled option, not the standard. HPTuners can also eliminate second O2 codes as well, but if you're not tuned I'd go for the angled option and save yourself the possibility of a CEL.
This was my first mod.
"Moon" [I jest].....
