2.0 Intake
Will a HHR 2.0 Ecotec turbo intake fit and work with a HHR 2.2 Ecotec engine? Boydie |
I suppose the answer would depend on whether you're turbocharging the 2.2 or leaving it normally aspirated.
OK let me clarify: Will a 2.0 turbo head fit on a 2.2 if I wanted to turbocharge the 2.2? Boydie
Originally Posted by 843de
(Post 773579)
2.0 and 2.2 have different bore and stroke, so No on that account.
Thank you fireman.:smile: How do Willwood brakes compare to Brembos? Boydie:roflol:
(Post 773596)
That would depend on rotor diameter and number of pistons in the caliper for clamping grip.
The bore & stroke of the eng has NO EFFECT on if the head will interchange you'd be best to look at head gaskets of each head if the bolt holes won't line up then don't try it if they do then you need to check if cam belt or chain is the same..
Originally Posted by skates
(Post 786136)
Stroke may not be a factor, but the bore sure can be. |
