Air intake
Old Jun 11, 2008 | 01:59 PM
masterchief1112's Avatar
Air intake
I see alot and i mean alot of hhr owners with the CGS intake. is this actually the best intake or is it just a piece of metal that looks good. before i bought one i am goiung to design a ram air that goes to the right instead of the left but if that does not coming out right i want to go with something else.
Old Jun 11, 2008 | 02:04 PM
solman98's Avatar
If I was going to buy one, it would be the GMPP unit.
Old Jun 11, 2008 | 02:51 PM
HipHotRod's Avatar
All of the "open element" types have a certain drawback which is a few HP decrease. The air filter sits right next to the engine and although it probably is getting better airflow, the engine compartment heat takes away the *cold* part of the cold air intake.
The GMPP, Airraid and the K&N use an air box to isolate the heat. I personally have the CGS for the cool factor. It opens up the view to those gorgeous twin cams. I also like the way an unrestricted intake sounds. I have noticed no difference in performance whatsoever and no effect on the MPG.
Old Jun 11, 2008 | 07:40 PM
Chevy SS's Avatar
Kind of true, if you are referring to the open element being the filter is not inside a box then you can easily have a cold air intake (longer pipe better filter postition) and increase HP and MPG. You are referring to the Short Ram Intake which is the one that puts the filter right next to the engine which is where most of the heat is so it kinda defeats the purpose.
An "open element" CAI would be better than SRI or stock with what mods everyone will be doing.
Old Jun 12, 2008 | 08:50 AM
okay here is what i am thinking for the intake i want to create before i but a cgs. i am going o have the filter go to the right of the engine instead of the left and pick up some of that fast moving air off the front of the car. I have tested it and there is about a 10 degree difference between the air temp here and where the cgs locates it element. then i am ggoing to create a make shift ram air tube for it. either run it up in front of the radiator or use one of the fog lamp holes (how do i get to these?). and if that does not look good and give me some power than i am callin up cgs. ill post pics as soon as i start on it.
Old Jun 12, 2008 | 08:55 AM
tireman1554's Avatar
The Airaide is the closest to "Ram Air" that I know of. Thats the one I use and can tell the difference. Sounds cool too.
drummerboy0088
2.2L Performance Tech
19
Feb 10, 2015 12:25 PM
Michael20832
2.0L Performance Tech
Jul 8, 2009 05:16 PM
