Bosch plat+4's no good
well in the last week i have had my hhr into paddock twice by tow ,the first time they told me it was the ignition module i got it back.so i drove around 4 about two days and it happend again ,got it towed there again and they replaced it again and this time they told me it went because of the bosch platnum+4s now i think this is a load of bs ...has ne body else had an issue with them and what should i do with the plugs
just a bit more on this when i did get it back the second time i was driving around for about an hour when my engine light came on so i drove back over to paddock and once again i am in a rental ..this time they are telling me that when they replaced my module the service tech cracked my air box and never told me about it ,,the service writer knew about it but failed to tell me about it .so end of story its sitting there waiting on parts..
Last edited by Hellraisehr; Jan 29, 2007 at 10:15 AM. Reason: a little more of the story
I have them in my 2.2L and have had no problems at all. I've had them in for about 5 months now.
I am a mechanic and there is no way that spark plugs no matter what kind would do that. there is no way they can feed back into the car and cause that.
All i can say is put your stock ones back in and see what happens to it then. If it go's again then you will know it wasnt the plugs and you can tell the shop that.
Plugs
When i put plugs in anything i always go with NGK's. I had a snowmobile that every time i started it i needed new plugs until i went with NGK's and they lasted until i stoped riding it a couple of years ago.
I wouldnt throw them away. Keep them and when you prove the shop wrong about the plugs just put them back in.
