yea I reset it then started it up. It was still cutting out and then i took it for a test run. It seemed to have figured it out but when I shut it off and started it later, it started cutting out again.
If the problem goes away but only returns after a restart then maybe a fuse blew that keeps the ecu powered. Kind of like a car stereo not keeping it's programming due to an issue with the REM wire I think.
Did you disconnect the battery before doing the install? |
Like my eclipse you should def try resetting ecu and letting car idle and warm up for a few minutes. Then get out and drive it and see if the problem is still there after a few days of city driving.
its not a fuse thats one way I tried to reset it so that cant be it. I think the MAF sensor is just messed up now. Gonna get a new one and try it out.
Originally Posted by The Thing
(Post 625038)
I was completely delicate with the MAF because I know how fragile it is. Does the MAF which looks like a 1 inch wide by 2 inch long rectangle have to extend all the way to the other side of the tube? if so theres the problem. tube is to big. but i did spot what looks like oxidizing on the MAF wires.
(Post 625055)
To test my theory run the car until it runs good then shut it off ten turn it back on within 2-3 minutes. The car will still be hot so it should continue to be in closed loop. Heck since we have coolant temp digital displays just watch the temp and compare it to how the car is running. |
okay i tried something new. I put the stock air box on. Took out the filter and put the CAI filter on the Stock air box. runs fine. so im gonna put piping in the stock box for more direct flow. If that helps then ill use that. then later on buy one of the ones made directly for the hhr.
I did try making sure the MAF was the exact same as the stock. but what i think it boiled down to was to much air getting to is at once. I guess. MAF works fine. |
What diameter is the tube where you have the MAF sensor? It has to be 2.5 inches or it will cause problems. I think the MAF mount made by Spectre is 3 Inch. You have to buy the adapter kit or make one. The adapter kit by Spectre works I believe but is more expensive.
it was 3in piping.I cut it and put the sensor straight in the pipe but i did notice on the stock box of the 2.2 has a slight angle of the MAF sensor. angling up probably helping air flow. I cut the MAF tube off the stock box and used that. works great! No codes or anything. Thanks everyone for the help. I've learned a lot!
1 Attachment(s)
Yep the 2.2 is sensitive to the MAF tube size,too large and the car runs terrible.I used the tube off of my stock airbox too. Attachment 26924
Originally Posted by us11csalyer
(Post 625056)
Did you disconnect the battery before doing the install? Does the batt have to be disconnected before doing a CAI? |
| All times are GMT -5. The time now is 07:46 AM. |
