Bank 1 lean indicates an air leak. Too much air after the MAF.
Thanks Ill check in to it.
Same problem solved
2 Attachment(s)
I did a similar intake change yesterday. Got the same code. I checked the inside diameter of the pipe where the maf sensor lives and it was 2.25. I changed from the 2.5 to the 2.25 and it runs great. No lights. No chugging.
Sbrice54, is your cah running with no codes being thrown, now, cause I took mine off, I think its because the Maf sensor tube I have on the the after market induction tube is too large, its 3"
maf sensor
I used the 2.25 inch tube insert.
Reworked Mine got it all working now throughing no codes and Im using a spectre Maf tube
https://www.chevyhhr.net/gallery/fil...5/ecotech1.jpg |
| All times are GMT -5. The time now is 12:21 AM. |
