custom turbo kit...
Old Oct 8, 2007 | 10:15 AM
en0oNmAI's Avatar
or search eBay for a Saab 2.0t Turbo. Its an ECOtec motor and has the exact same mounting for the exhaust manifold and will bolt up to our downpipes as well. Just thought I'd throw that out there since that is the route I am going.
Old Oct 8, 2007 | 12:16 PM
WhiplashHHR's Avatar
Do you know the years of the saab that these manifolds come off of? There is one on ebay now that might work.
Old Oct 8, 2007 | 05:04 PM
en0oNmAI's Avatar
Not quite sure of the years. I would imagine anything after 2001 would work since that was one of the first years that GM dropped its other 4cyl motors and adopted the ECOtec as its global motor.
Check around first just in case.
Old Oct 9, 2007 | 09:01 AM
monza's Avatar
this would be a great cheap start to get a turbo in the works... then you could adapt some of the oil taps etc to figure out what needs to be done...
Old Oct 10, 2007 | 03:01 PM
On my eclipse the turbo oil line was tapped into the oil presure switch on the back of the motor using fittings. It was as simple as that. And then a return line to the oil pan.
Old Aug 12, 2008 | 09:46 AM
masterchief1112's Avatar
anyone build a kit yet like this?
Old Aug 23, 2008 | 10:26 PM
doughboy's Avatar
not yet that i know of. but i did talk to a guy at chevy and he said that we could use the ss turbo kits for the lt's but couldn't run crazy boost!
Old Aug 24, 2008 | 09:49 AM
the SS turbo comes as a kit? or would you have to go and find all the parts? and what about programming..is that y you cant run crazy boost.
Old Aug 24, 2008 | 02:33 PM
doughboy's Avatar
im sure you could talk to your local gm service department and they could order it all for you. and no its because of compression, they dropped the compression for the ss the reason its a 2.0. but im sure you can tune it enough to make you satisfied.
Old Aug 24, 2008 | 10:16 PM
one issue how to tune a 2.2L? Id much rather get a SC rather than a TC but if its an easier route, AND CHEAPER, then ill think about it.
