FULL cold air intake with cgs.
Old Jul 14, 2009 | 11:29 AM
Krusty's Avatar
VERY ingenious! Although, I think the weak link in the chain is the metal tube under the hood. It will absorb LOTS of heat and will pass this on to the incoming cold air. I'd wrap it with insulation or replace it with something that doesn't conduct heat. Since my ride doesn't have factory fog lamps, I'm gonna drill out the plastic cover that takes its place. This should force cold air into the fender-well area where the factory snorkel can suck it up! No chance of inhaling water either!
Thanks for the idea Bro!!!
Old Jul 14, 2009 | 11:32 AM
txbass06's Avatar
So did it improve mileage any?
Old Jul 14, 2009 | 12:58 PM
Krusty's Avatar
OK....tried to yank out the plastic dummy fog-light cover, but it won't budge. I don't want to damage the paint by prying. Anyone know the trick?
Cheers!
Old Jul 14, 2009 | 01:03 PM
oneton's Avatar
It just snaps in, If I am thinking right there are two tabs you squeeze
Old Jul 14, 2009 | 01:09 PM
Krusty's Avatar
Yeh, but the back of it isn't accessible. Is there a panel someplace?
Old Jul 14, 2009 | 01:14 PM
oneton's Avatar
You have to take out the one or two 9/32" bolts on the bottom and a few push in tabs on the splash shield to get to the back side
Old Jul 14, 2009 | 02:45 PM
Krusty's Avatar
Got it! I thought it came OUT from the front, but it pulls backwards into the wheel well. The push in plugs are a pain to get out. I used the taper of my needle-nose pliers to push and pop them out. Thanks again.....gonna go for a spin and see if its turned into an SS....grin.
Old Jul 14, 2009 | 03:51 PM
Rcflyboy's Avatar
Great idea. AM looking forward to hearing how this works out. Should also be a little quieter I would think.
I have an Acura Integra and the cold air intake is in the exact same spot in front of the front tire and inside the liner. Has never gotten wet.
Old Jul 14, 2009 | 04:21 PM
HHRthunder13's Avatar
I did a mpg test and it did not improve or go down at all. Bummer. I was looking forward to see it go up but it didnt work. At least i got colder air coming to my engine!
Old Jul 15, 2009 | 01:12 PM
masterchief1112's Avatar
very good thinking i like it, now i think i know where im going with mine.
