whether you use it much or not your rev limit comes on FAST and nothing in your kit will save you from a blown engine. Activating TOO low can cause an explosion inside your intake manifold and happens a LOT with the ecotec motors. Hitting your rev limit too many times will blow the top end clean off. Even a 2nd gear pull with nitrous makes the 6500 come up VERY fast!!! Just a warning. My advice? play it safe and get a MSD Window Switch.
where would i get that switch?
(Post 174347)
REVISED EDITION....LOL https://www.chevyhhr.net/gallery/fil...3/100_1491.jpg |
Originally Posted by doughboy
(Post 174369)
From my understanding, the NOS set-up is designed to kick in at 'Full Throttle', how often do you expect to have an opportunity to be at full throttle, unless you`re on a drag strip or street racing?
A supercharger/turbo is much more street friendly, and give you a reasonable expectation that you can use it in day-to-day driving... Plus you don`t have to recharge. |
but nitrous is WAY chaper than a turbo.. :D
Originally Posted by RUDEINC
(Post 174394)
yea see i like the good gas mileage i have now, and i only want a kick when i want it not a constant waste of gas! plus like he said it is way way cheaper! plus if i ever have a problem i can take the nitrous out for warranty work! ;) also enoonmai how are your tail lights working with that paint on the i checked out your club site???
(Post 174680)
I don`t think I`ve ever even had my Turbo at wide-open-throttle, (while driving), and I know I`ve never done so in the HHR. |
is your hhr turbo??
| All times are GMT -5. The time now is 09:54 AM. |
