O2 sensor question
Originally Posted by donbrew
(Post 822648)
If it will run with the stock tune, that seems like the easiest.
I think the O2 sensor monitors runs continuously or twice a drive, so I don't know how it could "be not ready". I suppose you could try a battery disconnect lobotomy. What is stock tune? I have same problem. O2 Sensor : Incomplete also Evaporative Sys: Incomplete |
Sounds like your issue is for a 2.2 or 2.4, this thread pertains to the 2.0 Turbo SS |
"Not ready" means that the OBD2 test for the O2 sensors has not run. Did you disconnect the battery or clear codes recently?
What codes did you cl;ear? |
(Post 858593)
comandoed- no one can really help you much unless you answer the questions raised to help diagnose the problems you are having.
Ie: Donbrew has asked two questions that you even quoted, yet you did not supply any answers. |
Please follow thread more carefully. I am not asking for help. My initial question was "What is stock tune?". I was trying to simply educate myself.
The answer to his question, I thought was implicit when I replied that I had just bought the car 4 days ago and that that is how the car came. I commented about my "incompletes" for conversation sake only. Maybe I should not have. At this point I am not asking for any help. Sorry for the misunderstanding! |
Yes comandoed, please follow the "thread" more carefully.
This is a thread about the SS HHR. (it is in the SS specific forum) Your bio shows you have a 2007 so it is not a SS. You stated : quote "I have same problem. O2 Sensor : Incomplete also Evaporative Sys: Incomplete" To me, that reads as you've got a problem and you're looking for help. |
Stock tune is what comes from the factory.
BTW, I did follow the thread. Your first post was #6 and stated "same problem" but evidently is not. Bye. |
Thread separation, moved this to the 2.2 files. |
