Royal Purple Oils / Better Plugs
Thinking about changing my oils in my car to the Royal Purple complete. Also wondering about a good spark plug.
Your 2007 2.2 should already have AC Delco iridium tipped plugs as OE. They are quite excellent.
Originally Posted by da_dad66
(Post 205950)
If you switch to Royal Purple oils and have an oil related failure, it would likely be between you and Royal Purple for resolution - GM might not cover it. |
I just installed the Bosch 4482 +4 plugs in my 230 mile ride and I noticed a little more pick up right away.
:twothumbs
yep did mine some time ago. but i put in the plugs, kn air filter while doing the oil change with some mobil 1 this was about almost 3000 miles back and the dic is bearly at like 60 some % |
Mobil 1 all the way! If it's good enough for all vettes from the assembly line & the McLaren F1 cars, It's good enough for our ecotec sumps! :thumb:
I started out with Mobil 1 synthetic and last oil change switched to Penzoil Platinum Synthetic. The Penzoil seems to stay cleaner and last longer, so I may stay with it from now on. I changed the oil before I went to Kansas Speedway in July and have put on about 4,000 miles since then and DIC is at about 43% right now.
I also changed to Bosch +4 plugs quite some time ago. Seemed to have a little more zip after I did that. It's all a matter of opinion...and there are definitely a myriad of those here. :lol: |
Mobile 1 is the line of oil used at the dealership here in my town. And its recommended by GM. so I go with it. Havent changed the origingal plugs yet.
I switched to Mobile 1 after the first "free" oil change by the dealer. The last oil change was around 18K miles and now I have 25K. The DIC says 49%.
Originally Posted by jeffs396
(Post 211456)
For me, Pennzoil Platinum. |
