Royal Purple Oils / Better Plugs
Old Oct 19, 2007 | 09:38 PM
da_dad66's Avatar
Thinking about changing my oils in my car to the Royal Purple complete. Also wondering about a good spark plug.
Old Oct 19, 2007 | 10:41 PM
Lone Ranger's Avatar
Your 2007 2.2 should already have AC Delco iridium tipped plugs as OE. They are quite excellent.
Old Oct 19, 2007 | 10:56 PM
Black Rose's Avatar
Royal Purple oils are not on GMs approved oil list and Royal Purple does not say whether their oils meet the GM6094M spec.
If you switch to Royal Purple oils and have an oil related failure, it would likely be between you and Royal Purple for resolution - GM might not cover it.
Old Nov 11, 2007 | 02:31 PM
HHRcheater's Avatar
I just installed the Bosch 4482 +4 plugs in my 230 mile ride and I noticed a little more pick up right away.
Old Nov 11, 2007 | 03:10 PM
SIRESMERPH's Avatar
:twothumbs
yep did mine some time ago. but i put in the plugs, kn air filter while doing the oil change with some mobil 1 this was about almost 3000 miles back and the dic is bearly at like 60 some %
Old Nov 11, 2007 | 03:34 PM
jeffs396's Avatar
Mobil 1 all the way! If it's good enough for all vettes from the assembly line & the McLaren F1 cars, It's good enough for our ecotec sumps!
Old Nov 11, 2007 | 04:16 PM
courthousedeb's Avatar
I started out with Mobil 1 synthetic and last oil change switched to Penzoil Platinum Synthetic. The Penzoil seems to stay cleaner and last longer, so I may stay with it from now on. I changed the oil before I went to Kansas Speedway in July and have put on about 4,000 miles since then and DIC is at about 43% right now.
I also changed to Bosch +4 plugs quite some time ago. Seemed to have a little more zip after I did that. It's all a matter of opinion...and there are definitely a myriad of those here.
Old Nov 11, 2007 | 10:47 PM
Daverb's Avatar
Mobile 1 is the line of oil used at the dealership here in my town. And its recommended by GM. so I go with it. Havent changed the origingal plugs yet.
Old Nov 12, 2007 | 06:28 AM
Old Lar's Avatar
I switched to Mobile 1 after the first "free" oil change by the dealer. The last oil change was around 18K miles and now I have 25K. The DIC says 49%.
Old Nov 12, 2007 | 10:59 PM
Black Rose's Avatar
The Mobil 1 in the McLaren is not the same stuff you pick up at China Mart for $20
For me, Pennzoil Platinum.
