Temp guage working after clearing ECT code
Old Feb 9, 2018 | 10:29 PM
BERNS's Avatar
Hello All,
I noticed that my temp gauge was flat and I scanned my car and an ECT code was present and stated pending.
I decided to clear the code and once cleared the gauge started working.
Is this normal? Could it be thermostat starting to go out.
I am asking cause I was reading posts but nothing mentioned anything like my issue.
Old Feb 10, 2018 | 08:03 AM
It could be the thermostat, how old is your Dexcool (coolant), it has a 5 year life.
If it hasn’t been changed in awhile or you’ve never changed it since you bought the car change the thermostat and the Dexcool.
Just in case here’s the how to
https://www.chevyhhr.net/forums/how-...l-p0128-24493/
Old Feb 10, 2018 | 08:24 AM
As soon as the computer senses the temp is not where it is supposed to be at the right time the code and the display will come back, and your A/C will stop.
Your case is exactly the same as all of those others, assuming you mean P0128.
Old Feb 11, 2018 | 11:30 AM
Cat Man HHR's Avatar
X2 on this.
Old Feb 11, 2018 | 11:37 AM
And let me elaborate, by thermostat, I mean the correct AC Delco 131-158 180 degree thermostat.
And proper 50/50 mix Dexcool.
Old Feb 18, 2018 | 06:54 PM
BERNS's Avatar
Thanks to all. I ended up replacing the t-stat.
Previous owner is a co-worker so I asked him and he said he had changed it about 10k miles ago. Part looked a bit different than the AC Delco as it was a Napa brand stat.
I bought the AC Delco part and installed and put together in 20 min maybe less. It took longer for the car to circulate the coolant and fans to kick on.
Drove it for a solid hr including sitting at a del taco drive thru for 20 min and never overheated or flat temp gauge.
Daily is back on the road and back to enjoying after sitting for a week driving my weekend car due to no time and being dark by the time I got back from work.
All in all, this is as easy as replacing the t-stat on my old Caprice with 350 V8, that is cause I had all the right tools at hand.
This is an awesome forum.
Old Feb 18, 2018 | 09:24 PM
To explain for the umpteenth time; the code is because the coolant does not heat up FAST ENOUGH. It has nothing to do with over heating. The code causes the flat lining, not the other way around. It is more likely to occur in cool weather and when the coolant temp is lower than 190F.
Old Feb 19, 2018 | 02:14 AM
BERNS's Avatar
Thanks. I did not have an issue with overheating.
I was just mentioning that all went well, no code and no overheating from the stat not opening.
Everything works as it should.
Old Feb 19, 2018 | 09:09 AM
The p0128 code comes from the t-stat opening too soon or being stuck open.
Contrary to popular beliefs the t-stat has little to do with over heating. It's job is to keep the temp UP.
Old Feb 21, 2018 | 10:45 AM
BERNS's Avatar
Thanks. Makes sense.
Note that the reason I thought it was stuck closed was that my fans were running continuously on start up.
Leemor
Jun 9, 2014 06:33 AM
Beachbum1
Nov 25, 2012 03:01 PM
STR8SiqHHR
Dec 5, 2008 11:51 AM
cheroke75
Tires & Wheels
Aug 1, 2007 08:28 PM
