Trifecta Tuning Discussion 2.2
Old Dec 12, 2009 | 04:00 PM
TomsHHR's Avatar
Post your questions or discuss Trifecta tunes here
Old Dec 12, 2009 | 07:29 PM
masterchief1112's Avatar
ill start it off, can they tune for a custom turbo system.
Old Dec 12, 2009 | 09:30 PM
TomsHHR's Avatar
Yes your tune can be adjusted by gathering some data logging after the new turbo is installed.
We have a 2.2 Auto with a turbo that has a Trifecta Tune. Yes this is not a SS.
Old Dec 14, 2009 | 11:17 AM
re06xm's Avatar
i have a 07 2.2LT,all stock,i have heard great things about the trifecta tune.Q's:should i do the exhaust and intake before the tune and will any of these mods void my warranty? and is there anyplace in socal to get the tune?
Old Dec 14, 2009 | 04:57 PM
TomsHHR's Avatar
The tune and cable to install can be sent to you. No problems with that, Vince has sent a tuner out and If you have a laptop I have a Loaner cable you can use to do the install.
Yes do the intake and exhaust prior to doing the Tune is the best and saves some money. We can however perform a minor upgrade at a reasonable price if you chose to perform them at a later date.
Old Dec 15, 2009 | 05:40 PM
re06xm's Avatar
greatthanks for that info......i need to get started on the intake and exhaust first
Old Dec 17, 2009 | 10:58 PM
Raymond06's Avatar
So how does a 2.2 turbo with the tune run? can it go toe to toe with an ss? I live in the Atlanta area now is there anyone that tunes these little beast around here?
Old Dec 18, 2009 | 08:39 AM
Kevin3492's Avatar
Realistic changes with a tune?
Hi Tom,
I am curious, what kind of realistic changes I can expect with a tune without engine mods? As the factory ECM settings are designed for economy, service life, etc., how has Trifecta approached the 2.2l motor?
Thanks,
Kevin
Old Dec 23, 2009 | 11:14 PM
kwboydston's Avatar
Tom did the tune on my LS 2.2 the diff. I noticed was the dead spot on acceleration disappeared and when I keep my foot out of it (which is hard to do) I saw a mild increase in mileage of 2 to 3 in normal driving and if I am trying to hyper mile I see about a 4MPG increase of course I am not real good at hypermileing. I also noticed a faster 0-60 after the tune.
Old Jan 23, 2010 | 04:11 PM
HHRthunder13's Avatar
id like to get a tune but if something happens it would void warranty. Tom has anyone been able to "mask" the tune for the 2.2 yet?
