2.2 head on a 2.4 block
What do I need to do to make the wiring harness work for the 2.2 head
Is the 2.2 head from a later-model 2.2 that had VVT?
Steve |
The 2.2 from an ‘09,10 or 11 will fit, however there’s not much of a gain in , well , anything.
I know the old SBC trick of 305 heads on a 350 block, as the 305 heads had larger valves. I believe the SBF trick was 351 Windsor heads in a 302 block I’m sure many other combos. is this a matter of you have s 2.2 head? |
His bio shows that it's a 2006 "colbalt" ss. I would suggest asking over at the CobaltSS forum.
Originally Posted by Oldblue
(Post 866842)
It’s so long ago , I got the valves mixed up.
Yep, raise in the C/R. Also putting a 283 crank into a 327 would get ya a 302 hi-winder, as de-stroking it reduces stroke swept volume allowing it to rev to 7K.. Aka Z-28
Wasn’t that the set up, using 327 camel back heads? I recall 2.02 and 1.81 valve sizes.
I could Google it , but that was nearly 50 years ago. It makes me feel older , but not necessarily wiser! |
Yes those were the Hot heads to have. Also used on the "Fuelies" too.
I can relate to the older part, & the other. |
I was playing with 440 big block Dodges then.
