2.2 head on a 2.4 block
Old May 28, 2019 | 09:48 AM
Jason Sullivan's Avatar
What do I need to do to make the wiring harness work for the 2.2 head
Old May 28, 2019 | 11:11 AM
fastsuv's Avatar
Is the 2.2 head from a later-model 2.2 that had VVT?
Steve
Old May 28, 2019 | 11:52 AM
The 2.2 from an ‘09,10 or 11 will fit, however there’s not much of a gain in , well , anything.
I know the old SBC trick of 305 heads on a 350 block, as the 305 heads had larger valves.
I believe the SBF trick was 351 Windsor heads in a 302 block
I’m sure many other combos.
is this a matter of you have s 2.2 head?
Old May 28, 2019 | 02:12 PM
His bio shows that it's a 2006 "colbalt" ss. I would suggest asking over at the CobaltSS forum.
Old May 31, 2019 | 10:25 AM
Cat Man HHR's Avatar
The 305 would raise combustion ratio because of chamber volume, but they had smaller valves.
Old May 31, 2019 | 03:55 PM
It’s so long ago , I got the valves mixed up.
Old May 31, 2019 | 09:30 PM
Yep, raise in the C/R. Also putting a 283 crank into a 327 would get ya a 302 hi-winder, as de-stroking it reduces stroke swept volume allowing it to rev to 7K.. Aka Z-28
Old Jun 1, 2019 | 08:02 AM
Wasn’t that the set up, using 327 camel back heads? I recall 2.02 and 1.81 valve sizes.
I could Google it , but that was nearly 50 years ago.
It makes me feel older , but not necessarily wiser!
Old Jun 1, 2019 | 08:15 PM
Yes those were the Hot heads to have. Also used on the "Fuelies" too.
I can relate to the older part, & the other.
Old Jun 1, 2019 | 08:44 PM
I was playing with 440 big block Dodges then.
