91 octane = 172hp, 87 octane = ?
As for "Knock Learn Factor"... here's how HPTuners defines it:
(snip)
Hope that makes sense.
(snip)
I don't use HPTuners, but I'm acquainted with it because the guy who does all my cal work sometimes uses it and sometimes uses other software which allows him to access tables HPT doesn't display. While he's done my HHR, I wasn't present when he did it so I don't know which app. he used. I just mailed him the controller and he programmed it. The last car we did together was an '01 Camaro. Initially we used HPT but after he was able to defeat the double-check summing, we switched to his other application that allowed access to additional tables. As I recall, that ECM simply used either the high-oct. or low-oct. spark tables. It did not "interpolate" between them.
1. Overall fuel costs are almost a "wash" between gas octanes and MPGs in this engine. I think Snoopy did some good data that pretty much confirmed this.
2. Power level will be "somewhat" reduced with lower octane. GM even states ths. Now how noticeable this is is left to speculation.
Hey HIB, great write up on the oil...
I have been very confused ever since I bought my SS and had the GM6094 specification requirement.
I purchased some Valvoline Synpower 5W30 to use in my LNF and even contacted their technical dept who said it "Meets or exceeds the GM6094 specs", but have been afraid to use it as it is not on the GM approved list...
I see that the Red line is not listed as well, any idea of why that is?
Admittedly, this gives the appearance of risk to the consumer but really, the reputable small and "botique" refiners can be counted-upon to meet or exceed GM's standard. Red Line has been in business a long time. It wouldn't have remained sucessfull over the long haul, if it's products didn't meet or exceed those requirement.
That's a very brief explanation. A much more lengthy one was published a few years ago by Amszoil. It's located at http://www.performancemotoroil.com/A...Licensing.html
Also, can you recommend any other ester based oils to use.
I think I am going to start running 10W30 now that I have a better understanding of how they get down to 5W30 rating
Thanks in advance,
It', my contention that the elevation where you drive should have a lot to do with engine knock and what fuel grade you choose.
Some of you drive at very high elevations ... and should be able to run on low octane?
I'm in the valley where the Yukon River is 2100 feet so that's the lowest I can be. I'll try low octane for just low power around town driving on the next fill up.
Bottom line is that if you drive near sea level you should probably use high octane - all just my thoughts.
bigjacksauto
2.0L Performance Tech
18
Jul 25, 2012 10:40 AM
