airaid fit problem
Old Jul 13, 2008 | 12:38 AM
raven's Avatar
airaid fit problem
just put it on today and everthing went well. Except with the weather strip installed the hood doesn't close correctly (really tight). Anyone have his problem is there ideas I should try? Let me know.
Old Jul 13, 2008 | 01:29 AM
That's been the main complaint about the airaid.
Old Jul 14, 2008 | 11:00 PM
raven's Avatar
yeah but does anyone have a fix? I wonder what airaid has to say?
Old Jul 14, 2008 | 11:06 PM
It is supposed to create a seal with the hood. So I don't think there is a fix.
Old Jul 14, 2008 | 11:16 PM
oneton's Avatar
I took the rubber off and made a little slid with 2 straws and tape, closed hood, it pushed down the two straws, looked at how much room there was and cut down the rubber to fit, cut with a razor knife. about 1/16" longer so as to sit tight to under hood pad. Also made a front lip to go to the grill over rad.with thin sheet metal
Old Jul 14, 2008 | 11:27 PM
raven's Avatar
thanks oneton i'll have to do that. sounds like a good fix also for the front also. I'll post up later to let you'll know how this goes.
henr1e
Mods - Engine/Exhaust
Apr 28, 2014 11:58 AM
intofocuszx3
2.2L Performance Tech
0
Sep 15, 2007 05:49 PM
txsman2930
Jun 30, 2006 03:12 PM
