Another Option
Old May 15, 2006 | 06:27 PM
GPER's Avatar
Another Option
I was surprised to bump into this today. No dyno results, but another option to free up a couple of ponies.
http://www.performancecenter.com/pro..._2006/sf3_HHR/
Old May 15, 2006 | 06:37 PM
BlackHHR's Avatar
Looks like it would help.
I did what CJ did on his HHR.
I put a reactive air filter and a pipe to the Air filter box, after removing the stock filter.
Old May 15, 2006 | 07:52 PM
TNHHR1's Avatar
200 bucks for a filter and a plastic box
Old May 16, 2006 | 07:19 AM
hvrod's Avatar
Thats another good option.. price is moderate.. plus.. the box type enclosure helps funnel the air to the filter, and block some heat from the engine...
Old May 16, 2006 | 08:51 AM
Lee3333's Avatar
I would like to see the actual photo for an HHR. The picture they have is just a representation. If it mounts in the same location as the stock box, then it would be just as ugly covering up the entire engine. And the air would come from on top of the motor, which is pretty hot. The SoCal setup has the filter to the side, where it would get airflow from the wheelwell, like the stock intake did.
Old May 16, 2006 | 04:01 PM
killjoy's Avatar
Thumbs down air box
Price seems kinda steep for what you're getting.
Old May 18, 2006 | 09:49 PM
WA_HHR's Avatar
I like it!!!!!!!!!!!!!!!!!!! now what is the future for the funky look of the oil cap sticking up all goofy like
Old May 18, 2006 | 10:33 PM
SoCalHHR's Avatar
Here's the solution:
(Disregard red circle & arrow). Just twist the oil filler neck 1/4 turn and remove it. The oil filler cap uses the same threads, so it fits right into the valve cover. Problem solved.
Old May 19, 2006 | 09:53 AM
Firewatcher's Avatar
Found this on Ebay................
http://cgi.ebay.com/ebaymotors/Airai...67666459QQrdZ1
Old May 19, 2006 | 09:59 AM
hvrod's Avatar
Arrow
Originally Posted by Firewatcher
I found this one... 199.95 free shipping for orders over 150.00
plus if you order today save $15.00 by entering the code of "15NOW"
Gives you.. 8 more ponies, 8 more ft/lbs..
http://www.autoanything.com/air-inta...A1846A0A0.aspx
Kar Krazie
Jul 2, 2009 01:36 PM
pjtaxi
Oct 20, 2008 10:14 AM
savello
Aug 15, 2008 01:40 PM
pjtaxi
May 7, 2008 02:23 PM
pjtaxi
Jan 21, 2008 11:45 AM
