Cgs
Because since I cant mount it properly and someone else is interested in the one I got from you, I might have to go another route. I wouldnt ask you to take it back since its not your fault. It's GM's oversight, no holes drilled in the valve cover.
Gonna go on Angies *Blackie* I need to rethink this and see how I can mount it. I can get a stock CGS ( I think they are the best ones to get ) and maybe redo the bracket so it will mount to that rear sheet metal that houses the stock grommets that hold the stock airbox.
