CGS intake bolt size?
Old Sep 27, 2006 | 06:49 PM
dnvachon's Avatar
Angry CGS intake bolt size?
I did a search and came up empty handed but... does anybody know what size the "the supplied support strut bolt" for the support strut is? Mine must have fell out of the box or something... I didn't get one.
Any help would be greatly appreciated....
Old Sep 27, 2006 | 07:18 PM
courthousedeb's Avatar
Depends on what motor you have. I have the 2.2L so mine did not use the stock bolt that came with mine. Here's an excerpt from my how-to that deals with bolt size. Hope this is some help.
For those who need to adapt to the 2.2L, you need a 6 X 50mm bolt with 1" pitch and a flat washer. I got those from Ace Hardware, as the one that comes with the CGS is just a tad short according to both Mike & CJ.
Old Sep 27, 2006 | 07:31 PM
dnvachon's Avatar
Thanks for the info....
I have a 2.4L motor. I'll try your bolt info and see if it works.
Old Sep 27, 2006 | 07:34 PM
SoCalHHR's Avatar
The CGS bolts are: M6 x 25mm w/1.0 pitch thread.
They come packages inside a heavy plastic bag inside the box which also contains the instructions.
(If you have instructions, you should have a bolt. Check the bag again.)
If you are installing the CGS on a 2.2L engine, you will need a bolt the same but 1 1/2" inches longer to fit down into the valve cover recess where the coil plate is.
Hope it helps,
Old Sep 27, 2006 | 07:49 PM
nfboy's Avatar
Go back to where you bought it (so to speak) and tell them the bolt was missing or contact the manufacturer. Most will replace missing parts....
Old Sep 27, 2006 | 07:54 PM
dnvachon's Avatar
Thanks everybody..... I shouldn't have any trouble finding a bolt and washer at work now that I know what the size is....
wagoneer
Dec 25, 2014 11:00 AM
FatTireBiker
Oct 14, 2014 10:31 PM
NxlKing2304
Jan 24, 2014 11:34 AM
Electrical Master
27
Jan 5, 2012 11:28 PM
Lee3333
Jun 10, 2009 05:27 PM
