Engine cover
Old Jan 28, 2006 | 09:03 PM
SoCalHHR's Avatar
I'm pretty sure snksknr94 meant for that to go on the "fusebox" thread.
It happens...
Old Jan 28, 2006 | 09:06 PM
snksknr94's Avatar
What does that have to do with the plastic engine cover?
****. Could a forum nazi move that for me please!!!!!!
Old Jan 28, 2006 | 09:10 PM
SoCalHHR's Avatar
I'm surprised you didn't get "banned" for that!
(just kidding!)
Old Jan 28, 2006 | 09:13 PM
snksknr94's Avatar
I only get banned from sport compact boards. They dont seem to like the truth.
Plus they need to move as I'm trying to help out another member.
Old Feb 1, 2006 | 11:41 AM
SIHHR's Avatar
I'm thinking about this weekend if possible to start to paint some stuff under the hood
Old Feb 1, 2006 | 12:12 PM
  #26
SoCalHHR's Avatar
Just make sure you prep everything well - as the final paint job will only be as good as the prep and base paint applied. Take your time and do it right.
Good luck!
Old Feb 1, 2006 | 12:17 PM
  #27
captain howdy's Avatar
You're supposed to use adhesion promoter when painting plastics, not primer.
Old Feb 1, 2006 | 12:25 PM
  #28
SoCalHHR's Avatar
I never mentioned primer. If you are shooting candies or pearls you will need to use a base.
Old Feb 1, 2006 | 05:55 PM
  #29
SIHHR's Avatar
I'm going to use the spray can stuff. But i'm thinking about holding off untill I can get it done from a pro so I can get candy based paint instead.
Old Feb 1, 2006 | 06:02 PM
  #30
1st page.....
The important part about painting these items is preparing the plastic well with a light (1300 grit) sanding, then several light coats (4 or 5), of primer. If painting a metallic or pearl color, use 3-4 coats of base and 2-3 light coats of the color. I would also put a clear coat on top for protection.
