Jet performance module stage 1
what a waste!
i bought a stage 2 jet chip for my 2.4. i did 3 runs (0-60) without the chip (same engine temp and outdoor conditions etc. for both) and then did 3 runs with the chip and all 6 times were within .2 seconds of each other (fastest one without it). i am in the process of returning the chip. a trifecta tune is the way to go from what i hear...
The Trifecta Tune will help in different areas such as Throttle delay removal, adjust your HHR for your driving through data logging, if you have an automatic transmission, it will adjust your shift points and firmness.
Do you have a SS, 2.2 or 2.4 with std or auto?
You may find other questions and information on my Tune Center forum
http://www.chwtunecenterforum.com/portal.php
