Rpms?
Old 06-30-2017, 09:11 PM
BethnPete's Avatar
Rpms?
Just curious...what RPM should a 2008 2.4L be running at 55-60?
BethnPete is offline
Old 06-30-2017, 09:37 PM
Depends.
Auto or 5 speed ? And what gear is it in.
firemangeorge is offline
Old 06-30-2017, 09:38 PM
BethnPete's Avatar
Auto and I think third. I'm having shifting issues. I don't think it's going into low gear and not sure about high gear. Is it a 3 speed or 4?
Old 06-30-2017, 10:34 PM
Technical Moderator
4 speed; What issues, exactly. We may be able to help.
donbrew is offline
Old 06-30-2017, 10:39 PM
BethnPete's Avatar
It seems to start out ok, shifts at 25-30 and then doesn't shift any more. Changed fluid and filter, changed the intake solenoid and the (I think it is called) Trans control module. I can drive it at 55-60 running at 2500-3000 RPM
Old 06-30-2017, 10:40 PM
BethnPete's Avatar
Got a P/0100 error code
Old 06-30-2017, 10:43 PM
Technical Moderator
That means that there is a problem with the MAF circuit. Changed the air filter just before it came on?
Yes, it could cause trans problems.
2500 at 65 is about right.
donbrew is offline
Old 06-30-2017, 11:09 PM
BethnPete's Avatar
No, I don't think we changed it...perhaps we should?
MAF Circuit...sounds like more research :)
Old 07-01-2017, 06:10 AM
RPM's sound about right...
Greybeard999 is offline
Old 07-01-2017, 06:55 AM
aradmahogany's Avatar
My 06 2.4 is right about spot on at 2000 rpm going 55
aradmahogany is offline
Quick Reply: Rpms?
