New K&N Intake Available Now...
Old Sep 19, 2006 | 09:54 PM
  #61
JoeR's Avatar
Two comments re: the K&N dyno chart posted:
1. The numbers are the maximum difference between the two tests, which happened to take place at that RPM. Both make more HP further up the RPM range, but the difference is less.
2. Look at the top right of the chart where it says, "CF: SAE". That is the corrected horsepower figure that takes into account temperature, altitude and humidity. Really more accurate.
Dynojet's software actually records all the info from runs. You can view the recorded data in charts from many perspectives, SAE in this case or uncorrected and even DIN, the spec used in Europe and other standards.
Most of the numbers people have posted are uncorrected, which may "look" better, but make comparisons difficult, if not impossible in a situation where people start posting their results. I tried to point this out in another thread but the discussion was just getting interesting when the thread mysteriously got locked.
Old Sep 19, 2006 | 10:26 PM
  #62
SindyDix's Avatar
There was no mystery to it!
Old Sep 20, 2006 | 03:52 AM
  #63
DARK AGE 53's Avatar
Originally Posted by dnbguy86
They just shipped it out monday morning, and gave me a tracking number, so hopefully very soon it shall be here. If i can find time to get my fiancee's digital camera, ill post pics of that and my gmpp exhaust.
If you can, start your own thread so it dosn't get lost in this one.
Old Sep 20, 2006 | 02:59 PM
  #64
jluaces's Avatar
Fuel Mileage
Is there any documented fuel mileage gain or loss for this product or like products.
John
2007 2LT Amythst
Old Sep 20, 2006 | 08:52 PM
  #65
Applenut's Avatar
John
2007 2LT Amythst
As with any HP increasing product, it's all in HOW you drive. My mileage hasn't changed much after adding a CGS intake because I "drive it like it's stolen" on the weekends, and my wife drives it "normally" for her weekly commuting.
Old Sep 26, 2006 | 06:13 PM
  #66
61belair's Avatar
If you look at the notes you can see the graphs used are a second gear run. It doesn't say if its a manual trans or automatic, which will have different peak HP. Also the peak HP will change depending on what gear they did the run in. Gains in HP will also change depending on gear tested. As far as the airbox heating up, it should be very minimal as someone else stated the air isn't in the tube long enough to heat up. The other thing K&N does with their graphs is they find an average HP increase. Some vehicles may actually see more HP gain, but because K&N guarantees the HP they claim, they lowball it.
Old Sep 27, 2006 | 07:21 PM
  #67
HHR DLYT's Avatar
The Dyno run was with an auto trans. I know because that was my HHR that they used
Old Sep 29, 2006 | 10:16 AM
  #68
LarsBars's Avatar
Originally Posted by DARK AGE 53
If I had the K&N intake I would do a couple of things to make it look nicer, not alot of time invested and not much money.
1. Sand the intake tube smooth, using a primer and paint made for plastic I'd repaint it high gloos black.....with more time invested maybe the box also...or at least the top.
2. For looks I would get a silicone reducer hose, this hose would go over where the intake tube goes into the box. The only purpose of this hose would be for looks. Reducer hose pic, you can get it in red, blue and black.
3. For clamps I'd go with stainless steel T-bolt clamps. Clamp pic.
A few links for parts.
www.stylinmotors.com
For clamps http://www.hose-man.com/sys-tmpl/door/ Six locations in Cali.
www.bakerprecision.com Located in Cali.
The bottom line is if you're happy then that's all that matters.
Speaking of the link above for stylinmotors, I was just on another site and found this promo code. tried it and it worked. code is good for 20% off and the code is LS1.
This box does need some help that is for sure. I like your ideas.
Old Sep 29, 2006 | 10:26 AM
  #69
upOnGamE's Avatar
JUST GO TO INTAKEHOSES.COM if you want to start making things good customer service and products
Old Sep 29, 2006 | 10:33 AM
  #70
LarsBars's Avatar
Says they are closed.
