Oil light oddities!
Old 12-14-2018, 06:56 PM
Because the dipstick enters the pan at the front of the car and rests there at the front, yes any incline would give you a bad check on the level.
If the car is facing uphill,it would be a low reading. Facing downhill would show fuller than actual.
FYI. Checking a hot engine's oil level is never accurate. Oil is still accumulated through out the engine(especially up in the cam,valve area). Takes it a good 10 minutes or so to fully drain back.
Dipstick tube is the black pipe going into the oil pan.
firemangeorge is offline
Old 12-14-2018, 09:36 PM
George do you clean that SS everyday? Look at that , 8 years old and it sparkles!
Oldblue is offline
Old 12-14-2018, 09:41 PM
Oldblue. Just an old picture I keep recycling as needed. No where as clean as that now.
Old 12-16-2018, 03:53 PM
gio89kid's Avatar
If it is the oil pick up tube, should I replace it or just put it back on?
gio89kid is offline
Old 12-16-2018, 04:00 PM
Technical Moderator
I have never heard of it happening, and it looks pretty securely screwed in. So I don't know.
On older cars it kind of floated, so not common but not surprising to fall off or get clogged.
donbrew is offline
Old 12-16-2018, 04:17 PM
I think the oil pickup tube is very secure, judging by the number of bolts in the picture,
I circled the oil dipstick port
Oldblue is offline
Old 01-18-2019, 09:01 AM
gio89kid's Avatar
Ok, I haven’t had a chance to fix this yet or determine what it is.
But, I have been sure to pull over when the light comes on and check the oil. Oil has been good.
Recently however, light came on and was at two marks on the dip stick. I let the car sit and then it was barely registering on the dip stick. I started it up for a minute and then checked again and it was 3/4 marks on the dip stick. I drove it to get oil and it was again two marks on the dip stick. I added less than half a quart to get it to 3/4 at that time and then drove it home. Where now it sits.
by the way, unlike last time, this time the car was level every time.
I plan on changing the sensor, but now I want to check the compression and maybe attempt a leak down test.
The car went from barely using 1/4 mark on the dip stick between oil changes to now requiring a lot of oil it seems before an oil change is needed.
Advise please, thank you.
gio89kid is offline
Old 01-18-2019, 09:14 AM
Technical Moderator
To start: The "book" says anywhere between full and add is OK. Neither of mine had gradients, just 2 marks and the difference is about 3/4 quart (probably a litre).
As I read your post running the engine makes the level go up?
In my experience: checking the dipstick immediately after shutdown will be lower than if it sits for 10 minutes.
donbrew is offline
Old 01-18-2019, 09:42 AM
gio89kid's Avatar
Yes, that is what is weird?
it went down after sitting all day.
thats what I don’t understand. The car has been fine up until the oil has started hiding places?
one more thing that I am totally unsure of, I disconnected the crank case ventilation tube at idle to see if there was a lot of oil coming through there. There was oil, slight like usual but there was also air puffing out of there at a constant idle rate. Is that normal. I tried a catch can in the past and caught a little bit of oil but not nearly enough to empty after several oil changes.
gio89kid is offline
Old 01-18-2019, 09:45 AM
That’s fairly normal, I removed my oil catch can, I will reinstall it for the long highway trips, because I only get oil sucked out at higher RPM, this keeps the throttle body , oil free.
Oldblue is offline
Quick Reply: Oil light oddities!
