Realistic Horsepower numbers
I am looking for some realistic HP/TQ numbers. anybody have the airaid intake and jet stage 2 chip? if so do you have an idea or dyno numbers? I am guessing i am around 190-200 Horses with both but just looking for proof....
Solman is probably correct. BUT, I'll go one better......
Maybe 150-155 WHP. Not morre than 10 total for the TWO add-ons. I believe most STOCK 2.4's dyno around 141-147 WHP (which is the real method of recognizing HP).
I know that the "industry standard" line of thought for RWD rides is 15% parasitic/driveline loss...is it safe to assume the same for FWD?
All things the same:
172hpx85%=146.2 which would coincide with snoopy's suggestion. If you think about best case scenarios, you MIGHT put down 155 with those add-ons. 10hp* increase puts you up to 182*x85%=154.7
