tight fit
Old Apr 1, 2007 | 10:46 PM
ivtech's Avatar
Originally Posted by Bertland
I move the washer reservoir just abit to make room for the filter, I dont have the outlaw filter, it on is way, I will put pick when I will put it on
Is there a mounting stud at the bottom of the reservoir? I saw on mine that was room to move it at the upper 2.
Old Apr 2, 2007 | 08:22 PM
Bertland's Avatar
There are 3 bolt on the reservoir, 2 on the top and 1 on the bottom aside the pump wire grommet, I just make the top front hole(If you are on the passager side and you have the reservoir in front of you, it the RH bolt) off the reservoir a bit horizontaly bigger to bring the reservoir closer to the fire wall.
Old Apr 2, 2007 | 11:14 PM
ivtech's Avatar
Thanks Bertland
Old Apr 5, 2007 | 11:01 AM
Bertland's Avatar
Thanks Bertland
Bienvenue my friend
Old Apr 10, 2007 | 09:57 PM
rockNroad's Avatar
Red face tight fit trouble
Lots of noise under the hood. I popped the hood & what do I see.
1 outlaw filter flopping around loose well not flopping (not enough room)
also my cord for the block heater rubbing the crank damper.I' glad the belt
did not grab that cord ! It took about 5min to fix
later rNr // mike
Old Apr 14, 2007 | 05:40 PM
Bertland's Avatar
Here my installation pick Click here !
Old Apr 14, 2007 | 06:43 PM
rockNroad's Avatar
Bertland
Great post. When it warms up I'll take mine back out & redo as per your
instructions
rNr // mike
Old Apr 15, 2007 | 01:17 PM
Bertland's Avatar
Originally Posted by rockNroad
Bertland
instructions
rNr // mike
Thanks,
chella55
Tires & Wheels
Jun 11, 2015 06:23 PM
bigjacksauto
Maintenance and Upkeep
12
Jun 14, 2012 08:53 PM
garagebuilt
May 25, 2009 09:23 AM
