Turbo Install?
Old Mar 3, 2012 | 07:52 AM
us11csalyer's Avatar
Originally Posted by The Thing
like "bigjacksauto" said how does this kit look??
http://www.ebay.com/itm/350387696396...84.m1423.l2648
I mean im gradually learning things about the whole engine layout. And it looks like it has everything. Turbo, BOV, intercooler, downpipe, exhaust manifold.
I wouldn't buy a kit off ebay, but what I would take away from it is the list of parts it includes. Gives you a good idea of what you will want.
Some things you should research or do:
With an upgraded fuel pump you should get bigger injectors and an adjustable fuel pressure regulator.
Going for >300hp you should still get a quality turbo. Its not just about the power it makes but at what band it makes it at.
Putting a lip on ic piping is a good idea
Adjustable cam gear
I can't stress enough of the importance of a wideband and starting with no more than 2psi of boost. Its like overclocking a CPU. Take it slow.
Running a little rich is much safer than running a little lean.
Knock count is very important. You should understand this and advance/retard timing.
Another issue I saw a lot is people starting their car after install with no oil in the turbo.
RaSScal
Dec 20, 2013 05:31 PM
Nok817
2.0L Performance Tech
22
Apr 1, 2012 12:29 PM
hhr_2009
2.2L Performance Tech
Mar 1, 2011 09:12 AM
hhr_2009
Sep 10, 2010 02:27 PM
GDZHHR
2.4L Performance Tech
Dec 14, 2009 09:40 PM
