RPO Code lists (Options)
Old Jan 15, 2008 | 07:33 AM
ralphb's Avatar
Inside the glove compartment of the HHR, there is a tab showing all the factory build codes for the equipment and options on that particular vehicle.
Does anyone have a reference that details the contents of these codes ?
Old Jan 15, 2008 | 11:59 AM
an08HHR's Avatar
From the Edmonds.com site you can find this when you do a price with options, seems there are some threads out there on the forum also. http://www.edmunds.com/new/2008/chev...n=1&x=116&y=14
KBB.com http://www.kbb.com/KBB/NewCars/Optio...ng&YearId=2008
Old Jan 15, 2008 | 12:22 PM
Snoopy's Avatar
I think, the original poster should request this as a "stickey". Questions come up frequently regarding an option and build code.
Old Jan 15, 2008 | 02:51 PM
ralphb's Avatar
I believe that my question was misunderstood. I don't mean ordering codes for a new vehicle. (Although some of the codes are the same as the codes used for ordering)
The codes I am talking about are build codes that show all factory items that were installed on the car, such as :
Type of transmission; Axle final drive gear ratio; Rear sway bar; Brake system, Seats; Interior color code,etc. It shows the paint code for the exterior, and what type of paint was used. It breaks down every item that would have been a choice for a worker on the assembly line. There are about 50 such codes listed on my 2008 HHR SS, most of them being 3 digit alpha numeric codes. It is much more extensive and inclusive than the codes used by a dealer ordering a new vehicle.
I have seen these codes for older GM products, but I don't know where to find a listing of the codes for current products.
Old Jan 15, 2008 | 03:13 PM
The following thread may be what you're looking for........
https://www.chevyhhr.net/forums/general-hhr-4/2008-rpo-codes-10645/
I know it says for 2008 RPO codes but many are the same as my 06.
Old Jan 16, 2008 | 02:01 PM
ralphb's Avatar
This is great !
It has some of the SS codes, but not all of them. Apparently, it has not been updated.
Old Jul 30, 2008 | 05:01 PM
Norsican's Avatar
Anyone find an RPO code list for the 2007 HHR?
Old Jul 31, 2008 | 03:12 PM
Retrorod's Avatar
My RPO code list is old, I've contacted my sources (as a Dealer Service Manager) and requested an update RPO list.
Old Aug 1, 2008 | 10:00 AM
ChevyMgr's Avatar
2007
2007 Chevrolet HHR | HHR (VIN A) Service Manual | Document ID: 1757267
________________________________________
RPO Code List
RPO Description
AJ6 Adjuster - Seat, Power, 6-way, Vert, Driver
AL0 Sensor Indicator - Inflatable Restraint, FRT Pass/Child Presence Detector
AP3 Lock Control, Entry - Remote, Keyless Entry, Start
AR9 Seat - FRT BKT, Deluxe
ASF Restraint Roof Side, LH and RH, Inflatable
ATY Seat RR - Not Installed (Seat Belts, Labels, MTG Hardware)
AXP VIN Ident - Position, Multi-Purpose Vehicle
BVE Steps, Runningboard, Side
B36 Covering - Floor Mat, Luggage Compartment
B57 Ornamentation - EXTR, Deluxe
CF5 Roof - Sun, Glass, Sliding, Electric
CV3 Country - Mexico
C2Y GVW Rating - 4,240 lbs
C67 HVAC System - Air Conditioner FRT, Electronic Controls
DD8 Mirror I/S R/V - LT Sensitive
DG7 Mirror O/S - LH and RH, Remote Control, Electric, Color
DT4 Ashtray - Cigarette Lighter
D22 Mirror O/S - LH and RH, Remote Control, Electric
FE1 Suspension System - Soft Ride
FE3 Suspension System - Sport
FE9 Certification - Emission, Federal
FR8 Ratio - Transaxle Final Drive 4.17
FX2 Ratio - Transaxle Final Drive 3.91
G63 Provisions - Luggage Carrier, Roof
JM4 Brake System - PWR, FRT Disc, RR Drum, Cast Iron, Antilock FRT and RR WHL
J41 Brake System - PWR, FRT Disc, RR Drum, Cast Iron
KA1 Heater - Seat, FRT
K05 Heater Engine - Block
LE5 Engine - Gas, 4 Cyl, 2.4L, MFI, Alum, DOHC, HO, ECOTEC
L61 Engine - Gas, 4 Cyl, 2.2L, MFI, Alum, DOHC
MM5 Merchandised Trans - Auto Provisions, O/D
MN5 Transmission - Auto 4 SPD, HMD, 4T45-E
MX0 Merchandised Trans - Auto Provisions, O/D
M86 Transmission - MAN 5 SPD, GETRAG, 5T45-E, M, F23, 75MM, 3.58 1st, 2.02 2nd, 1.35 3rd, 0.98 4th, 0.69 5th
NE1 Certification - Emission, Geographically Restricted Registration for Vehicles up to 14,000 lbs, GVW (Use 2003 Mdl Yr)
NF4 Emission System - Clean Fuel Fleet
NP5 Steering Wheel - Leather Wrapped
NT7 Emission System - Federal, Tier 2
NU1 Emission System - California, Lev 2
NW7 Traction Control - Powertrain Management Only
N24 Steering Wheel - Plastic, 3 Spokes
N85 Wheel - 17 X 6.5, Aluminum
QBV Tire All - P215/50R17-90S BW ST TL AL2
QB5 Wheel - 16 X 6.5, Steel
QDB Tire All - P215/55R16-91S BW R/PE ST TL AL2
QDJ Tire All - P215/55R16-91H BW R/PE ST TL AL3
QG9 Wheel - 16 X 6.5, Aluminum, Machined Face
QP2 Wheel - 17 X 6.5, Aluminum Polished
Q8H Mud Flaps - FRT and RR, Formed
SAL Plant Code - Ramos Arizpe, Mexico
T37 Lamp - Fog, Deluxe
T62 Lamp System - Daytime Running - Delete
UE0 Communication System - Vehicle, G.P.S. - Not Installed
UE1 Communication System - Vehicle, G.P.S. 1
UQ3 Speaker System - Enhanced Audio
US8 Radio - AM/FM Stereo, Seek/Scan, CD, Auto Tone, Clock, ETR, MP3, RDS
US9 Radio - AM/FM Stereo, Seek/Scan, RDS, Multiple Compact Disc, Auto Tone Control, Clock, ETR, MP3
UW5 Speaker System - 6, Base
U1C Radio - AM/FM Stereo, Seek/Scan, CD, Clock, ETR
U2K Digital Audio System - S-Band
U19 Speedometer, Inst, Kilo and Miles, Kilo Odometer
VPM Modification - Noise Control, Mexico
VK3 License Plate Front - FRT Mounting Pkg
VY7 Knob - Trans Control Lever, Leather
V73 Vehicle Statement - Delete
V78 Vehicle Statement - Delete
YF5 Certification - Emission, California
Z49 Export - Canadian Modif Mandatory Base Equip
1LS Package - LS Option 1
1LT Package - LT Option 1
2LT Package - LT Option 2
Old Aug 1, 2008 | 10:05 AM
ChevyMgr's Avatar
2008
2008 Chevrolet HHR | HHR (VIN A) Service Manual | Document ID: 1905453
RPO Code List
RPO Description
AT8 Restraint Provisions - Child, RR Seat, RR Facing
AXS VIN Ident - Panel Van
CW4 Country - Caribbean (Antigua, Antille, Bahama, Barbados, Bermudacayman, Dominican, Haiti, Jamaica, Nassau, S.M. Trinid)
CZ1 Country - Central America (Belize, Costa Rica, El Salvador, Guatemala, Honduras, Nicaragua, Panama)
D48 Mirror O/S - LH and RH, Remote Control, Electric, Color
D81 Spoiler - RR, Aero Wing
EXP Export
FE5 Suspension System - Ride, Handling, Performance
FQ7 Ratio - Transaxle Final Drive 4.05
FR9 Ratio - Transaxle Final Driver 3.29
G85 Axle - Limited Slip, FWD
JL4 Control - Active Brake
JL9 Brake System - PWR, FRT Disc, RR Drum, Cast Iron, Antilock, FRT and RR WHL
IPB Trim - Interior Design (PB)
IP2 Trim - Interior Design (P2)
LNF Engine - Gas, 4 Cyl, 2.0L, DI, Alum, DOHC, TURBO, GM
MU3 Transmission - Man 5 Spd, SAAB, 76.5 mm, 3.38 1st, 0.70 5th
M86 Transmission - MAN 5 SPD, GETRAG, 5T45-E, M, F23, 75 mm, 3.58 1st, 2.02 2nd, 1.35 3rd, 0.98 4th, 0.69 5th
NU2 Emission System - California, ULEV2
NZ6 Wheel - 16 X 6.5, Steel, High Vent
PZ4 Wheel - 18 X 7.5 Aluminum, Polished
TBD Tire All - P225/45R18 AL3 All Season
T43 Spoiler - RR
T96 Lamp - Fog, FRT
VGG Protector - RR Bumper
VT7 Owners Manual - English Language
Z49 Export - Canadian Modify Mandatory Base Equip
