RPO Code lists (Options)
Inside the glove compartment of the HHR, there is a tab showing all the factory build codes for the equipment and options on that particular vehicle.
Does anyone have a reference that details the contents of these codes ? |
From the Edmonds.com site you can find this when you do a price with options, seems there are some threads out there on the forum also. http://www.edmunds.com/new/2008/chev...n=1&x=116&y=14
KBB.com http://www.kbb.com/KBB/NewCars/Optio...ng&YearId=2008 |
I think, the original poster should request this as a "stickey". Questions come up frequently regarding an option and build code.
I believe that my question was misunderstood. I don't mean ordering codes for a new vehicle. (Although some of the codes are the same as the codes used for ordering)
The codes I am talking about are build codes that show all factory items that were installed on the car, such as : Type of transmission; Axle final drive gear ratio; Rear sway bar; Brake system, Seats; Interior color code,etc. It shows the paint code for the exterior, and what type of paint was used. It breaks down every item that would have been a choice for a worker on the assembly line. There are about 50 such codes listed on my 2008 HHR SS, most of them being 3 digit alpha numeric codes. It is much more extensive and inclusive than the codes used by a dealer ordering a new vehicle. I have seen these codes for older GM products, but I don't know where to find a listing of the codes for current products. |
Originally Posted by ralphb
(Post 228660)
Does anyone have a reference that details the contents of these codes ? https://www.chevyhhr.net/forums/general-hhr-4/2008-rpo-codes-10645/ I know it says for 2008 RPO codes but many are the same as my 06. |
This is great !
It has some of the SS codes, but not all of them. Apparently, it has not been updated. |
Anyone find an RPO code list for the 2007 HHR?
My RPO code list is old, I've contacted my sources (as a Dealer Service Manager) and requested an update RPO list.
2007
2007 Chevrolet HHR | HHR (VIN A) Service Manual | Document ID: 1757267
________________________________________ RPO Code List RPO Description AJ6 Adjuster - Seat, Power, 6-way, Vert, Driver AL0 Sensor Indicator - Inflatable Restraint, FRT Pass/Child Presence Detector AP3 Lock Control, Entry - Remote, Keyless Entry, Start AR9 Seat - FRT BKT, Deluxe ASF Restraint Roof Side, LH and RH, Inflatable ATY Seat RR - Not Installed (Seat Belts, Labels, MTG Hardware) AXP VIN Ident - Position, Multi-Purpose Vehicle BVE Steps, Runningboard, Side B36 Covering - Floor Mat, Luggage Compartment B57 Ornamentation - EXTR, Deluxe CF5 Roof - Sun, Glass, Sliding, Electric CV3 Country - Mexico C2Y GVW Rating - 4,240 lbs C67 HVAC System - Air Conditioner FRT, Electronic Controls DD8 Mirror I/S R/V - LT Sensitive DG7 Mirror O/S - LH and RH, Remote Control, Electric, Color DT4 Ashtray - Cigarette Lighter D22 Mirror O/S - LH and RH, Remote Control, Electric FE1 Suspension System - Soft Ride FE3 Suspension System - Sport FE9 Certification - Emission, Federal FR8 Ratio - Transaxle Final Drive 4.17 FX2 Ratio - Transaxle Final Drive 3.91 G63 Provisions - Luggage Carrier, Roof JM4 Brake System - PWR, FRT Disc, RR Drum, Cast Iron, Antilock FRT and RR WHL J41 Brake System - PWR, FRT Disc, RR Drum, Cast Iron KA1 Heater - Seat, FRT K05 Heater Engine - Block LE5 Engine - Gas, 4 Cyl, 2.4L, MFI, Alum, DOHC, HO, ECOTEC L61 Engine - Gas, 4 Cyl, 2.2L, MFI, Alum, DOHC MM5 Merchandised Trans - Auto Provisions, O/D MN5 Transmission - Auto 4 SPD, HMD, 4T45-E MX0 Merchandised Trans - Auto Provisions, O/D M86 Transmission - MAN 5 SPD, GETRAG, 5T45-E, M, F23, 75MM, 3.58 1st, 2.02 2nd, 1.35 3rd, 0.98 4th, 0.69 5th NE1 Certification - Emission, Geographically Restricted Registration for Vehicles up to 14,000 lbs, GVW (Use 2003 Mdl Yr) NF4 Emission System - Clean Fuel Fleet NP5 Steering Wheel - Leather Wrapped NT7 Emission System - Federal, Tier 2 NU1 Emission System - California, Lev 2 NW7 Traction Control - Powertrain Management Only N24 Steering Wheel - Plastic, 3 Spokes N85 Wheel - 17 X 6.5, Aluminum QBV Tire All - P215/50R17-90S BW ST TL AL2 QB5 Wheel - 16 X 6.5, Steel QDB Tire All - P215/55R16-91S BW R/PE ST TL AL2 QDJ Tire All - P215/55R16-91H BW R/PE ST TL AL3 QG9 Wheel - 16 X 6.5, Aluminum, Machined Face QP2 Wheel - 17 X 6.5, Aluminum Polished Q8H Mud Flaps - FRT and RR, Formed SAL Plant Code - Ramos Arizpe, Mexico T37 Lamp - Fog, Deluxe T62 Lamp System - Daytime Running - Delete UE0 Communication System - Vehicle, G.P.S. - Not Installed UE1 Communication System - Vehicle, G.P.S. 1 UQ3 Speaker System - Enhanced Audio US8 Radio - AM/FM Stereo, Seek/Scan, CD, Auto Tone, Clock, ETR, MP3, RDS US9 Radio - AM/FM Stereo, Seek/Scan, RDS, Multiple Compact Disc, Auto Tone Control, Clock, ETR, MP3 UW5 Speaker System - 6, Base U1C Radio - AM/FM Stereo, Seek/Scan, CD, Clock, ETR U2K Digital Audio System - S-Band U19 Speedometer, Inst, Kilo and Miles, Kilo Odometer VPM Modification - Noise Control, Mexico VK3 License Plate Front - FRT Mounting Pkg VY7 Knob - Trans Control Lever, Leather V73 Vehicle Statement - Delete V78 Vehicle Statement - Delete YF5 Certification - Emission, California Z49 Export - Canadian Modif Mandatory Base Equip 1LS Package - LS Option 1 1LT Package - LT Option 1 2LT Package - LT Option 2 |
2008
2008 Chevrolet HHR | HHR (VIN A) Service Manual | Document ID: 1905453
________________________________________ RPO Code List RPO Description AJ6 Adjuster - Seat, Power, 6-way, Vert, Driver AL0 Sensor Indicator - Inflatable Restraint, FRT Pass/Child Presence Detector AP3 Lock Control, Entry - Remote, Keyless Entry, Start AR9 Seat - FRT BKT, Deluxe ASF Restraint Roof Side, LH and RH, Inflatable AT8 Restraint Provisions - Child, RR Seat, RR Facing AXP VIN Ident - Position, Multi-Purpose Vehicle AXS VIN Ident - Panel Van BVE Steps, Runningboard, Side B36 Covering - Floor Mat, Luggage Compartment B57 Ornamentation - EXTR, Deluxe CF5 Roof - Sun, Glass, Sliding, Electric CV3 Country - Mexico CW4 Country - Caribbean (Antigua, Antille, Bahama, Barbados, Bermudacayman, Dominican, Haiti, Jamaica, Nassau, S.M. Trinid) CZ1 Country - Central America (Belize, Costa Rica, El Salvador, Guatemala, Honduras, Nicaragua, Panama) C2Y GVW Rating - 4,240 lbs C67 HVAC System - Air Conditioner FRT, Electronic Controls DD8 Mirror I/S R/V - LT Sensitive DG7 Mirror O/S - LH and RH, Remote Control, Electric, Color DT4 Ashtray - Cigarette Lighter D22 Mirror O/S - LH and RH, Remote Control, Electric D48 Mirror O/S - LH and RH, Remote Control, Electric, Color D81 Spoiler - RR, Aero Wing EXP Export FE1 Suspension System - Soft Ride FE3 Suspension System - Sport FE5 Suspension System - Ride, Handling, Performance FE9 Certification - Emission, Federal FQ7 Ratio - Transaxle Final Drive 4.05 FR8 Ratio - Transaxle Final Drive 4.17 FR9 Ratio - Transaxle Final Driver 3.29 FX2 Ratio - Transaxle Final Drive 3.91 G63 Provisions - Luggage Carrier, Roof G85 Axle - Limited Slip, FWD JL4 Control - Active Brake JL9 Brake System - PWR, FRT Disc, RR Drum, Cast Iron, Antilock, FRT and RR WHL JM4 Brake System - PWR, FRT Disc, RR Drum, Cast Iron, Antilock FRT and RR WHL J41 Brake System - PWR, FRT Disc, RR Drum, Cast Iron IPB Trim - Interior Design (PB) IP2 Trim - Interior Design (P2) KA1 Heater - Seat, FRT K05 Heater Engine - Block LE5 Engine - Gas, 4 Cyl, 2.4L, MFI, Alum, DOHC, HO, ECOTEC LNF Engine - Gas, 4 Cyl, 2.0L, DI, Alum, DOHC, TURBO, GM L61 Engine - Gas, 4 Cyl, 2.2L, MFI, Alum, DOHC MM5 Merchandised Trans - Auto Provisions, O/D MN5 Transmission - Auto 4 SPD, HMD, 4T45-E MU3 Transmission - Man 5 Spd, SAAB, 76.5 mm, 3.38 1st, 0.70 5th MX0 Merchandised Trans - Auto Provisions, O/D M86 Transmission - MAN 5 SPD, GETRAG, 5T45-E, M, F23, 75 mm, 3.58 1st, 2.02 2nd, 1.35 3rd, 0.98 4th, 0.69 5th NE1 Certification - Emission, Geographically Restricted Registration for Vehicles up to 14,000 lbs, GVW (Use 2003 Mdl Yr) NP5 Steering Wheel - Leather Wrapped NT7 Emission System - Federal, Tier 2 NU1 Emission System - California, Lev 2 NU2 Emission System - California, ULEV2 NW7 Traction Control - Powertrain Management Only NZ6 Wheel - 16 X 6.5, Steel, High Vent N24 Steering Wheel - Plastic, 3 Spokes N85 Wheel - 17 X 6.5, Aluminum PZ4 Wheel - 18 X 7.5 Aluminum, Polished QBV Tire All - P215/50R17-90S BW ST TL AL2 QB5 Wheel - 16 X 6.5, Steel QDB Tire All - P215/55R16-91S BW R/PE ST TL AL2 QDJ Tire All - P215/55R16-91H BW R/PE ST TL AL3 QP2 Wheel - 17 X 6.5, Aluminum Polished Q8H Mud Flaps - FRT and RR, Formed SAL Plant Code - Ramos Arizpe, Mexico TBD Tire All - P225/45R18 AL3 All Season T37 Lamp - Fog, Deluxe T43 Spoiler - RR T62 Lamp System - Daytime Running - Delete T96 Lamp - Fog, FRT UE0 Communication System - Vehicle, G.P.S. - Not Installed UE1 Communication System - Vehicle, G.P.S. 1 UQ3 Speaker System - Enhanced Audio US8 Radio - AM/FM Stereo, Seek/Scan, CD, Auto Tone, Clock, ETR, MP3, RDS US9 Radio - AM/FM Stereo, Seek/Scan, RDS, Multiple Compact Disc, Auto Tone Control, Clock, ETR, MP3 UW5 Speaker System - 6, Base U1C Radio - AM/FM Stereo, Seek/Scan, CD, Clock, ETR U2K Digital Audio System - S-Band U19 Speedometer, Inst, Kilo and Miles, Kilo Odometer VGG Protector - RR Bumper VK3 License Plate Front - FRT Mounting Pkg VPM Modification - Noise Control, Mexico VT7 Owners Manual - English Language VY7 Knob - Trans Control Lever, Leather V73 Vehicle Statement - Delete V78 Vehicle Statement - Delete YF5 Certification - Emission, California Z49 Export - Canadian Modify Mandatory Base Equip 1LS Package - LS Option 1 1LT Package - LT Option 1 2LT Package - LT Option 2 |
