Accessories not working
I have an HHR ls that is a rebuilt salvage. I put a roof cut in from an lt with a sunroof and roof rails. All of the wiring in my new headliner simply plugged in and I assumed the sunroof would work. it didnt. Same goes for the heated power SS seats and associated switches I installed. I called the dealership after I had checked everything I knew to check ( fuses, voltage at the switch, made sure the sunroof motor worked) and they asked for my vin before even attempting to troubleshoot the problem. The service writer then informed me that my car, the car I just told him I had rebuilt, was a salvage title and I don't know what kind of shoddy work was involved. Clearly he either wasn't listening at all or didn't want my buisness. So I thought I'd turn to the lovely people of this forum. how do I fix my various electrical problems. I've heard that the dealership can go in and turn "ON" accessories in their computer. Is this what I need? Or is there a switch or fuse I need to swap.
The service guy was trying to tell you that the computers need to be programed, which may be problematical since they usually are only trained to do it by VIN.
In other words; You can only add option that are available to the VIN.
Yes , the computer in the car has to be programmed for the accessories it is "supposed" to have according to the VIN and the build sheet for that vehicle.
The problem I see is a GM dealer may not be willing to reprogram it for you because of the salvage status. Because of this and the fact that it's "pieced together" (for the lack of a better term ), a dealer may not want to accept any liabilities due to this salvage status.
Example; If the dealer programs your car to activate these accessories, then the wiring gets fried because of bad salvage work that was done, well, the dealer could be blamed.
I know that back in my mechanic days if someone brought a car to our shop like that I would decline to work on it.
As some have said, perhaps wiring to switches yourself instead of through the system, is an option. Depends on your level of competency with wiring and comfort with doing the wiring job you do.
Now, as far as the OP and his salvage car, we're talking a different scenario.
One thing that caught my attention in the 1st post: "I put a roof cut in from an lt with a sunroof".
I used to do a lot of mechanic work for a used car/ wholesale company through the shop I worked at. I have seen a lot of salvaged and "brought back from totaled" vehicles. Some former repairs made you go WTH. Others were just down right dangerous.
