Back to Match- CJ's 2 Tone
Old May 2, 2006 | 05:08 PM
cj krause's Avatar
back was easier.
1 used a butter knife to take off yellow part only.
2 then scraped off silicone (different than front) and 3M tape on side of back
3 then took a small vise grips and grabbed posts at base and twisted off- both
4 applied 3M to both base on back and inside the new blue bowtie
5 used a black dry erase marker to get the exact middle of each on top
6 kneeled and watched lines on bottom to make sure they line up and dots on top, lightly touched it together, no pressure, looked to see if straight then pushed all the way down all over to seat it
Old May 2, 2006 | 05:23 PM
KY Dave's Avatar
Mine is blue, just like yours. I love that look. Where did you get them????
Old May 2, 2006 | 05:26 PM
cj krause's Avatar
http://cgi.ebay.com/ebaymotors/NEW-1...spagenameZWDVW
Old May 2, 2006 | 05:34 PM
deadhead's Avatar
Looks great CJ and I mailed off your cds today
Old May 2, 2006 | 05:38 PM
O6ChevyHHR's Avatar
wow Cj those blue Bowties look great!
Old May 2, 2006 | 06:11 PM
BlackHHR's Avatar
Looking good CJ. love the blue on blue look.
I just painted mine black. I'll see how long the paint will last.
Old May 2, 2006 | 06:41 PM
Lee3333's Avatar
Looks great. I tried to get the gold bow tie off, before you posted instructions. Look what NOT to do:
[IMG][/IMG]
What happened is I rushed. I got excited seeing how good yours was, and I tried to remove it with a screwdriver and no heat gun. Then, I had to take my son to a doctors appointment, so when I got home at 4, I was anxious to finish getting the pieces off. I applied heat and it came off great, but I decided to remove the base. Again, I rushed (bust my chops now, CH) and I removed the inside panal looking for the mounting nut. Once off, I began thinking again and realized there was no access there. So, I tried removing the hatch switch. Again, no access, so I went back to my trusty heat gun and got the base off. Now, I am left with a larger, nearly perfectly flat spot to work with. The only imperfections are 2 small post holes and one casting depression. I just picked up some spot putty, and as soon as I can break away from my wife and kids, will smooth it out then decide what to put there. My local parts stores had nothing. I may try a vinyl bowtie to match my flames (yellow) or reflective tape cut to fit.
Old May 2, 2006 | 06:46 PM
BlackHHR's Avatar
Ouch!
Are you going to put the red ones that CJ found on?
Man they would look good.
Old May 2, 2006 | 06:56 PM
Lee3333's Avatar
That would be an idea. CJ-speak to me.
Old May 2, 2006 | 08:00 PM
cj krause's Avatar
http://cgi.ebay.com/ebaymotors/NEW-6...QQcmdZViewItem
he has some negative comments but i called him, they took my card and got both out that day. was a nice transaction. he was only slow on answering one email.
