Bowtie replacement
Old Aug 28, 2010 | 09:39 PM
Doctor Who's Avatar
Bowtie replacement
I was on ebay and found replacement billet aluminum bowties for the HHR. Has anyone tried these before?
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old Aug 28, 2010 | 10:01 PM
peevlos's Avatar
I don't know it only shows a front bow tie and only give one set of measurements, although the add states its for a pair. The bow-tie on the rear of the HHR is smaller and flat
Also if you super size it, it does not seem angle enough from the center out either perpendicularly or horizontally. Our front bow-tie bends in both directions.
I also wouldn't listen to them as far as using a small screwdriver to remove them Use fishing line
Old Aug 28, 2010 | 10:12 PM
Also when you supersize that photo that certainly isn't "polished to a mirror finish"...... Note that the listing states it's "NOT an exact replacement". I wouldn't buy them.
Old Aug 28, 2010 | 10:15 PM
Doctor Who's Avatar
After posting it, I did the same thing. I read the listing more closely and looked closer at the pics. He also sells an anodized black set, but if they aren't exact fits, then what is the point. Thanks for the input.
Old Aug 28, 2010 | 11:36 PM
Contact Summit Racing, they can get them from Street Scene..
Like $40.- $45. a piece.
There is also at least one thread here on Billet Bow-ties for our rides.
Old Aug 29, 2010 | 01:59 AM
patrick49's Avatar
Looks like crap, I wouldn't buy. I have mine painted black and they look great.
Old Aug 29, 2010 | 02:44 PM
Doctor Who's Avatar
That is what I am thinking of doing now that I have checked out that auction a little closer. Any paint suggestions for painting them black?
Old Aug 29, 2010 | 04:13 PM
GOLFHHR's Avatar
I ordered them in black from this supplier. I put them on a precision billet grille and the rear. They were ordered in a pair front and back. They both were the same as to the slight bend they had ? So I ended up banging the crap out of the front one to put more bend in it so it would contour the billet grille to stick properly and I had to bend the back one because their was too much bend from the supplier. As a result the paint was damaged and I ended sanding the paint off them and sprayed them with clear coat. The final result was a brushed aluminum finish which looked better than the stock black. I am happy with how it turned out, but it was a very frustrating experience. They should have had 2 different bends for the front and back, maybe they miss shipped the bowties.
Old Aug 30, 2010 | 03:52 AM
patrick49's Avatar
My friend at the dealership had his guys there do my bowties. Assuming they used standard GM paint and clear. The raised part of the bowtie is black and the chrome bezel is still stock.
Old Aug 30, 2010 | 07:30 PM
flyhhr's Avatar
i replaced mine in the rear takes time but it was for a 94 chevy s-10 front grill and just used double sided tape
