chrome replacement antenna
Old May 8, 2006 | 01:19 PM
Question chrome replacement antenna
Anyone know of a chrome replacement antenna which will work with the HHR?
Went to Advance auto and the had a big selection but their "universal" wasn't.
Old May 8, 2006 | 02:10 PM
cj krause's Avatar
Lots of antennaes on Ebay in chrome
just make sure you get the right diameter. most come with 2 different diameters
Old May 8, 2006 | 02:12 PM
courthousedeb's Avatar
You might check with crazybob...he got one off ebay and said it was a VW chrome antenna. Only problem I have with chrome one is that the base is black and it might look a little odd...but that's just me. Hope this helps.
Old May 8, 2006 | 02:15 PM
The problem I'm running into is that the fittings either go into the antenna too far or not enough.
I've already tried 6. That's why I was hoping that maybe someone had found one that worked.
My experience with ebay, on which I've made 100's of transactions-buying and selling, is that it is often difficult to tell if an item will work or is even close to what is described.
I'm sure that anyone who has ever used ebay has at least one story like this.
Thanks Deb!
Old May 8, 2006 | 05:44 PM
cj krause's Avatar
Jetta is what i found that worked
Old May 8, 2006 | 05:50 PM
Any place in particular?
Old May 8, 2006 | 06:34 PM
Thanks CJ and Deb!
Found this one on ebay.
Marcruger
Aug 27, 2009 05:50 PM
15
Jul 16, 2006 09:25 PM
