Clear-Corner Lenses
Clear-Corner Lenses
I tried doing a search both here and other websites. All I found here was people that said they were going to take apart their headlights to take the amber reflector out of the light housing. Has anybody actually done this yet?
Also, do they make those bulbs that appear silver/chrome but glow amber for the HHR, or are those universal-fit?
Any/all help appreciated.. Thanks!
I don't recall seeing anyone disassemble the stock lamp. Not sure offhand if the lens is heat-melted together or uses caulk. If the former it is possible to cut them apart and then re-seal with silicone. I've done that before on other lenses but it took several hours of careful cutting with a dremel.
To answer the second part of your question about the bulbs, the corner bulb is a 3157, we have those in Chrome/Amber, see here: http://www.truckshop.com/product.php?productid=18486
There is some glue holding the headlight case. I think they said it was heated up to help soften it and started working it apart and did that over again till they go it off. Also I think they said the they amber colored housing has to be broken to take it out.
I know thats not much help but I know it can be done and is a pain from the way it sounded.
Thanks for the info... One more thing... I don't really want to do this to my stock headlights (time, might screw up.. can't drive w/o headlights)... So does anybody know what the part number for the lights is?
Thanks again!
Thanks again!
Retroburban's husband purchased an extra set of the light pods. After separating the clear from the shell, he painted the chrome interior, not used to directly reflect the light beam, to match the color of her HHR, Met. Red. It appears the lamp pods are composed of 3 sections that are "siliconed" together. He heated the units to a certain temp, which I do not recall, to gently separate the sections. I believe the amber reflecter would need to be cut out with a dremel like tool, to remove.
I suggest you PM Retroburban an ask if her husband could provide accurate disassembly.
One thing he an I agreed on......
Removing the original pods and replacing with the new painted ones, will be a chore. Appears like almost the entire front assembly, bumper, etc. will need to be removed.
Good luck....keep us informed
Thanks Snoopy knew I could count on you to help me out.
Now that I think about it for some reason I am thinking he heated them up to about temp of around 300. I could be wrong.
I would do what Snoopy said a PM Retro
The link provided by airborne is good info for the actual mod of the headlight pod. That person suggests 210 degrees for 20 minutes and I believe that was what I was told by Retro's husband.
But the removal process in that link is nothing like what it will entail to remove the pods from the HHR. Much more difficult.
