Dash top removal
Old Oct 22, 2009 | 05:05 PM
Father Azmodius's Avatar
Dash top removal
Ok, I finally got somewhat motivated to start this project. I want to take the top of the dash off for some smoothing and paint, but have run into a little snag. I can't seem to get it off. I have removed the RPD and the screw behind it, the 2 screws under the top of the waterfall, and the 2 screws under the A pillar covers. I have also removed the 2 screws from the instrument bezel.The issue I seem to be having is around the pass. airbag. Can anyone help?
Old Oct 22, 2009 | 10:32 PM
The airbag is held in with 2 nuts (10mm). After those are removed then the cover must be pried from the dash top.
Old Oct 23, 2009 | 02:39 AM
prod's Avatar
So after that did it come off?
Old Oct 23, 2009 | 07:57 AM
lunchbox's Avatar
hey, could you take a few pics or somethin. once i finish my door panels i wanna do the dash next. i was just gonna wrap it in suede though. let me know how the smoothing works for ya. good luck
Old Oct 23, 2009 | 04:20 PM
Pics will be forthcoming. Once the airbag is removed the top pulls off. To remove the cover for the airbag 6 ( or 8, I don't remember ) tabs must be bent up so the cover can be pried over them. Note.......I unplugged the module just inside the passenger side kickpanel before I did anything else with it. The wire leading up to the module is taped to 2 retainers that need to be pried from their respective holes. Oh yea, the clearance for the socket ( which must be a deep well ) is such that with an extension on it, it puts it at an odd angle, so you either need a universal, or to get the ratchet up in the dash. The thought of trying to smooth the bezel for the RPD has me questioning whether I really want to go that far, so I may just end up painting it
Old Oct 25, 2009 | 01:45 PM
sethwas's Avatar
Interested in seeing how this works out.
Seth
Old Oct 26, 2009 | 03:41 PM
I did some preliminary painting yesterday. I'll do a few topcoats tonight and determine whether I'll need to sand off the texture. Pics to follow
Old Oct 26, 2009 | 04:29 PM
doughboy's Avatar
keep us updated please, i have been thinking of this as well
Old Nov 1, 2009 | 06:14 AM
VictorySpeedway's Avatar
I wanted to glue the stalk for my GPS to the dashboard storage bin lid. I was going to buy a new lid and install it when I sell the HHR in a few years.
But, after reading about removing the dash (which, I assume, will be necessary in order to replace the storage bin lid), I've decided to do something else.
YIKES!!!
Old Nov 1, 2009 | 11:14 AM
I don't have the storage bin, but I think it should come out without having to remove the dash top. Should be 3 screws if I remember correctly
