Fog light covers?
Old Nov 28, 2006 | 07:49 AM
jbmcb's Avatar
Fog light covers?
When I was scoping out HHRs a few months ago, one dealer had a tricked-out model with body-paint matched, vent-style fog light covers. It looked pretty slick, and probably a good idea since they are so low to the ground, and Michigan roads tend to sand-blast anything that far down on a car.
Does anyone know where to find these? I called the dealership and they are clueless, even though they are the ones who souped up the car in the first place.
Old Nov 28, 2006 | 01:02 PM
SoCalHHR's Avatar
The "vent-style fog light covers" you saw are on all HHR's that do not have fog lights. They are simply plastic inserts that fill the fog light holes:
Hope it helps,
Old Nov 28, 2006 | 01:14 PM
jbmcb's Avatar
Yep, that's what I saw. Dang, they look nice, too. Oh well, are there dark/translucent caps available? I'd think that would be one of the first aftermarket items made for a vehicle...
Old Nov 28, 2006 | 01:28 PM
courthousedeb's Avatar
If they are available...I don't remember seeing anyone mention them here...and we don't miss much.
As Mike said...what you see are the stock covers that come on the HHR with no fog lamps. Mine have the same thing as above and I have a 1LT with no fog lights. I'm sure a crafty person could remove the original ones, cut out the center vent area and put in something like you're talking about though.
Old Nov 28, 2006 | 08:59 PM
RatRodS's Avatar
Are 3M covers available for the fog and headlights?
Old Nov 28, 2006 | 09:59 PM
SoCalHHR's Avatar
Not just yet.
Old Nov 28, 2006 | 11:27 PM
Snoopy's Avatar
Actually, yes it is. One place is the link below. You may need to custom order. The other method is to buy a piece from someone that stocks the 3M Paint Protection product in bulk rolls (usually auto paint suppliers or the film installers themselves).
The application to a relatively flat surface is easy, if you take your time and think it out. It gets very difficult when you try to apply it over curved and radiis areas, where it needs to be stretched correctly.
http://www.clearmask.com/
Old Jul 14, 2009 | 01:05 PM
Krusty's Avatar
Anyone know the trick for popping out those plastic covers?
Old Jul 14, 2009 | 06:45 PM
HHROwner's Avatar
I used a flat blade screwdriver from the front with a twist....seemed to work ok.....
Old Aug 14, 2009 | 09:40 AM
solman98's Avatar
Originally Posted by whiteford1
Is there much to adding factory fogs or is it better to use aftermarket?
I originally went with aftermarket. Later I got my hands on a set of the stocks and swapped those out and still used my aftermarket wiring.
I have a thread here with what I did. Quick search should locate it for you.
