Has anyone smoothed their dash?
Old Feb 18, 2006 | 02:20 PM
ngiovas's Avatar
Junior Member
Has anyone smoothed their dash on their HHR? Does anyone know where I can find out more info on doing this? I'm thinking that if I get the HHR I would want to build a new console and smooth the dash, but I'm trying to find out more information about the process of smoothing a dash.
NG
Old Feb 18, 2006 | 02:28 PM
Holmes Hot Ride's Avatar
NG
What is smoothing the dash? If that means to get a flat looking no curve dash, why?
One of the things I like about the HHR is its dash and old look intruments.
Old Feb 18, 2006 | 02:46 PM
captain howdy's Avatar
He means sanding off the little plastic dots that stick out I think.
Old Feb 18, 2006 | 02:49 PM
SoCalHHR's Avatar
NG
Basically you just pull the dash parts and start with a belt sander. Remove most of the bumps evenly, then switch to hand sanding with a finer grit until you get it smooth. Erich from Darkside told me he spent many, many hours sanding their HHR dash to get it smooth before painting!
One thing to think about; for daily driving a smooth a gloss painted dash is going to cause a lot of problems with reflected sunlight - the pebbled dash makes the most sense.
Hope it helps,
Old Feb 18, 2006 | 03:08 PM
ngiovas's Avatar
Junior Member
Is any kind of filler used? I was worried that filler or paint may crack since the dash is somewhat flexible. One of the reasons I am thinking of doing this is so that if I build a custom console they will match. I may just pull out the trim pieces around the radio and make them match the console.
Old Feb 18, 2006 | 03:12 PM
SoCalHHR's Avatar
I think most people just sand all the bumps off and then smooth it all over. You will need to use adhesion promoter when painting plastic. If you used a filler, you should make sure it is compatible with plastic and then use it all over the entire surface. This way you would get a consistent finish.
Personally, I'd stay away from filler for the reasons you mentioned.
Old Feb 18, 2006 | 03:15 PM
Skatetheglobe's Avatar
so thats how they got the smooth painted door panels..that looks nice..
Old Feb 18, 2006 | 03:57 PM
SIHHR's Avatar
If its an daily driver then to me it does not make sense. But if you plan to do a show car, then it would make more sense to do as suggested. Sorry just my two cents
Old Feb 18, 2006 | 04:32 PM
SoCalHHR's Avatar
Exaaaactly! Once you drive into glaring sunlight, you will most likely re-think having that area smooth.
Believe it or not, the engineers at Chevy knew what they were doing.
Old Feb 18, 2006 | 09:15 PM
Thanks Howdy! Boy! Am I out of tune with the times. It must be true what they say another mans junk can be another mans treasure.
joekat
Mods - Interior
Jun 2, 2012 12:28 PM
Wolfie
Mar 25, 2011 01:27 AM
jpmcnam58
11
Jun 6, 2009 04:21 PM
TkHHR
11
Nov 3, 2008 09:49 PM
giant96
May 1, 2007 04:07 AM
