Has anyone tried tail light leds
Has anyone replaced the stock tail light bulbs with direct fit LEDS? I see on some sights they may not work with the GM computer controled wiring. I assume it will not acknowledge the bulb because of the low amp draw.If you have done this include a link as to what you used. Also, would the flasher have to be replaced for one that accepts LEDS. I just did my license plate lights and they worked fine.
Yeah, I recently installed THESE and I love them. As you suspect, they create a hyperflash situation- which I actually like and may not change- because the computer thinks they're burned out. You need the load resistors to get back to the 80 flash/minute stock rate. If anyone knows why I shouldn't leave the flash rate fast, please post here.
you may get haslled by the police since the classic sign of a burnt bulb is that fast flash, they may stop you thinking its burned out. I guess it could get you a fix it ticket????
Originally Posted by R CA HHR
(Post 210003)
I've never done LED's before so I have no experience with this. Gonna have to investigate. |
I meant if they see the front flashing fast they may think the rear on the same side is burnt and either pull ya over or follow you to see if it is burnt. Its a long shot but I thought it was worth stating. When I change over to led I'll most likely let the thing flash fast and see if I like it. I see alot of lil hondas runnin' around with that going on and it kinda lets ya know they did it wrong or didn't do it completly and I don't think I would want people thinking I did a half ars job on it.
That computer controlled wiring never crossed my mind, what was wrong with the old method most of us understood. Battery, wire, brake, switch, light bulb, that was so simple, don't know why they had to stick a computer into the circuit. I know,, create jobs, increase cost, heck I don't really know:confused: :confused: , somebody must.
I think the Spyderlites are better. They have more LED's on the front than those and also have some on the back of the "legs", so more light gets reflected like the stock bulbs.
Originally Posted by 1Panel2NV
(Post 210070)
Mine do have a row of lights around the "sides" that bounce off the reflectors. That's a must IMO. |
im getting ready to do a custom LED taillight.
gonna do the ring of LEDs as running lights and have an LED bulb as the brake and turn. |
I got the lights and load resistors used for $50. That's the only reason I have them. I'm thinking about replacing them with IPCW's, whenever they release them.
The lights on ebay would be $30 shipped for two. Spyderlites are a little more, but they're worth it. |
| All times are GMT -5. The time now is 06:04 AM. |
