Help!!! Zinik 20" Wheels
Old Jan 2, 2008 | 06:47 PM
btthomas's Avatar
Does anybody know if you have to cut anything or if thay will scrub on a 2008 panel?
Old Jan 2, 2008 | 06:51 PM
1Panel2NV's Avatar
If you get the right tires, there shouldn't be a problem. Unless you are planning on lowering it also. Not sure what tire size though, I like 17'' better.
Old Jan 2, 2008 | 07:05 PM
stick's Avatar
Last I knew, if you lower then you will have to roll the fender on the rear for sure and not sure about the front. If you don't lower you should be good to go.
Old Jan 3, 2008 | 05:36 AM
btthomas's Avatar
What size and brand tire if money is no prob?
Old Jan 3, 2008 | 05:37 AM
btthomas's Avatar
the way crowbar's HHR looks is killer!
Old Jan 3, 2008 | 06:35 AM
SLVR FOX's Avatar
i have 235-30-20 tires on my 06.
never rubbed. i haven't rolled my fender lips either.
Old Jan 3, 2008 | 05:09 PM
stick's Avatar
Did you lower the rear at all?
Old Jan 3, 2008 | 05:14 PM
Found in another thread.......
20" ADR propulsion in Hypersilver with 235-30-20 Nitto tires, Goldline springs
Looks like they are 2nd gen GLs.
Old Jan 3, 2008 | 06:23 PM
SLVR FOX's Avatar
yup. whatever goldlines truckshop.com had left is what i bought.
i've had 4 bags of salt and 3 other passengers and never rubbed.
Old Jan 3, 2008 | 06:38 PM
stick's Avatar
Sweet! I'm hoping to run 20s when the weather gets better. Just don't want them to rub and get all screwed up.
