Leaking washer fluid from rear headliner
Old Dec 29, 2020 | 05:47 PM
KidsHHR's Avatar
Hello, my daughters 2006 LT is leaking washer fluid in the rear headliner and when I pulled it down there is a black check valve looking thing that is in the line that is leaking. I can't find any information on this piece and assume it has some importance so I really don't want to just splice the two lines together unless I know it's okay. Any ideas? I did do a thread search and couldn't find any thing.
Old Dec 29, 2020 | 06:13 PM
What about a wrecking yard ? Get one off of any year HHR. They should be the same for all years.
Old Dec 29, 2020 | 08:01 PM
I don't recall any
. Exactly where? You could blow into it to see if it is a check valve. The black bits I recall are connectors.
Number 9 is the tube.
Old Dec 30, 2020 | 09:56 AM
geg's Avatar
geg
one guy from Belarus got this problem.
I must say that parts of the HHR in Belarus are not sold on every corner.
So he just took the broken part in his hands and went shopping. He bought the first one he came across, roughly matching the diameter of the tubes. It turned out to be a piece of Toyota. As far as I know, it still works fine. It's been five years or more.
I know about this case because this Belarusian wrote to me and was interested in the price in Russia.
Old Dec 31, 2020 | 05:29 PM
KidsHHR's Avatar
Found the part
Old Dec 31, 2020 | 08:17 PM
Makes sense to have a check valve there, so the pump won't lose it's prime.
Old Dec 31, 2020 | 09:32 PM
I believe any valve is in the pump.
phenderson51
Jan 21, 2014 02:46 PM
scrambler
Jan 13, 2009 02:17 PM
Teflonworm
Mar 1, 2007 08:42 AM
Black Rose
Nov 30, 2006 12:13 AM
Lee3333
Jan 18, 2006 09:39 PM
