LED Switchback question, 06 specfic
Are the switchback LED just plug in like a standard bulb (minus load resistors) or is there some other wiring?
What I'm wondein is, on the 06 HHR, the bright side of the front markers/signals is the DLR. I've wondered if I installed a set of switchbacks, would my DLR be white or amber? I'd like to have them white with the DLR's, then normal operation with headlights on. But without something to connect them to the DLR system, it seems like they would be amber with the DLR (along with the signal flash) and only white with the running lights.... Did I ask that right? :lol: |
i think they would be white at all times..and then turn yellow when signal is activated
That depends....were you trying to make my head spin ????
They didn't require any additional wiring on the BMW, SS's (3) or the panel. But none of them are a 06. Should try a set....if they light up backwards, switch the wires. :thumb: |
ive been running the switchbacks for a year now no issueshttps://www.chevyhhr.net/gallery/fil..._755_thumb.jpg
do u need resistors?
Originally Posted by skyline26
(Post 690706)
Originally Posted by SS fan
(Post 690708)
Originally Posted by capp002
(Post 690712)
(Post 690715)
im using LEDs inside without problems and for my brake/reverse/rear signals without resistors and no problem..so im wondering if switching the fronts to LED will throw it off then the hyperflash will start
(Post 690719)
http://smg.beta.photobucket.com/user...econs.mp4.html |
looks good :)
