They are either glued or plastic welded together. They do come apart though. I ran a razor blade around it and they popped apart. Cutoff wheel on a dremel would probably be better.
If pics would help I may have some of what you're looking for... I cut the lenses off of the set I did. They where junk anyway so it was easier to hack them off then separate them.
