Rear Fender Rust
Old Nov 5, 2011 | 10:00 AM
Draper 06 HHR's Avatar
Question Rear Fender Rust
So I have the rust problem at the base of my rear doors and rear fender. I went and bought the running boards and I am going to fix the paint soon.
My problem is that the rust has started to get bigger and has started to move underneath of the factory fender protector. Has anyone removed these? Are there fasteners from the inside or is it held on with some sort of adhesive?
Thanks
Old Nov 5, 2011 | 10:05 AM
pyro panel's Avatar
Former Sponsor
I have sum started as well..same spot..what do u mean by factory protector??inner fender well??..as for the running boards they fasten underneath with torx head screws..should be 3 of them..look up..just above the jack points..
check my thread on lake pipes...I used the same fastener points for the pipes that the running boards use..
Old Nov 5, 2011 | 12:07 PM
On the rear panel in front of the wheel well there is a piece of plastic that is
Either stuck on with fasteners or adhesive
Old Nov 5, 2011 | 12:32 PM
Those rear fender protectors are stuck on with adhesive tape I believe.... there are no fasteners.
Old Nov 5, 2011 | 08:04 PM
Lucky's Avatar
yep no fasters just glue. I dont think you can reuse them. they cost about 35.00 to replace them
Old Nov 5, 2011 | 09:09 PM
There's two different types.... the older type were thick painted plastic and can be reused if carefully removed. Newer ones are clear tape throwaways.
sking1973
Apr 11, 2014 08:12 AM
DarkKnight
Sep 11, 2013 01:18 PM
DaytonaBlueMetallic
Nov 22, 2012 01:26 AM
dbdfan2006
Sep 7, 2009 07:12 AM
SandyBeach
Oct 17, 2006 07:43 PM
